MSGGrunt said:I just called Pep Boys and they have the Hayden here for $69.99. Same price almost as the Unknown Chinese POS. I will be returning the Torque Quest and getting the Hayden unit.
ed97fzj80 said:and I'm really really surprised Dan hasn't said anything one way or another about this. NTTIAWWT . . . maybe there is nothing to say about it at this time.
I'm not experiencing any heat issues at the moment, so no immediate need for a new clutch. I'm betting it needs to be replaced though. Was going to do it as PM. I'm planning on doing the temp gauge mod real soon.landtank said:right now I'm liking my tweaked Blue over the Hayden/Imperial. With some more positive testing I think this is the way to go.
But if you need one right now I think the Hayden/Imperial is your best bet.
LandCrusher'70 said:I'm not experiencing any heat issues at the moment, so no immediate need for a new clutch. I'm betting it needs to be replaced though. Was going to do it as PM. I'm planning on doing the temp gauge mod real soon.
landtank said:once you get that guage fixed you might see the need a little more clearly. I think it comes down to tolerance on this issue. Some seem perfectly happy to have their trucks run up above 210*, for me I think that is too high and want something closer to 180* as my high temp mark.
dgangle said:I was told by Charlie Thurman at Superior Radiator in MI that when at temperature, if you shut the engine off at idle and the fan rotates more than 2X, then the clutch fan is bad. This has worked for me in the past. Not vey scientific and subject to debate, I'm sure.
So is this a goof on Toyota's part? I can't see the reason the Blue hub would've been designed this way.landtank said:From what I can see the blue clutch is designed to come on gradually as the need for cooling increases so does the drive. So with the exception of startup, you won't hear a roar when it's on. My problem was that it was coming on late. So as the cooling demand increased the clutch followed but was behind the need and therefore allowed the truck to get hot. Now that I've advanced the timing of the clutch the truck maintains proper operating temps and there is still no roar as the clutch is engaged just enough to maintain the temp.
I feel the issues with the blue clutch is strictly a calibration issue and nothing more. And a properly calibrated blue will be the best option for cooling, power and MPG that anyone could get on one of these trucks.
LandCrusher'70 said:So is this a goof on Toyota's part? I can't see the reason the Blue hub would've been designed this way.
