SUMOTOY said:Rick:
I've read your methodology with great interest. My concern is that your technique has effectively raised the rpm of a given fan. As I found out the hard way, over ~4500>redline, this absolute fan rpm becomes a recipe for fans eating radiators. A less viscous fluid would do two things IMO, come on sooner (good) and increase absolute fan rpm (bad or ugly or worse). Thoughts?
I've pretty much come to the conclusion that runs to redline on these trucks and overall reduction in heat would be best accomplished with electric fans. You lose a lot of nose cone weight and balance issues (more with SC spacers in), you can over ride the fans to 'off' when "water crossing", you can pick a variety of fan speeds, CFM, sizes, number, and many turbo cars have some impressive fans with circuits (I had the tape measure on a turbo volvo one just this afternoon). Summit actually carries some pretty impressive 5600cfm dual fan units that use a progressive speed thermostat, and smart relay control that has over ride for Fan on-A/C, Fan on-override, Fan off-override, and LED status.
So 'best option' might need to include 'for an engine driven fan', but I'm convinced electrics can add more flexibility with a lot of benefits I just don't see with hte engine driven fan as I move my supercharged 80 toward redline.
Your thoughts?
Scott Justusson
Scott, one thing to remember is I had a clutch that allowed the engine to run extremely hot. So while I might have advanced the clutch's timing by 10* it was on a clutch that when the engine was at 240* it provided no drive to the fan at all.
So a clutch that provides some cooling, but still allows an engine run slightly hot, adjusting that clutch to the same spot as mine would be less of an advancement to it, maybe something like 5* or even less.
The fear of over driving the fan was a concern to me as well and why I've avoided thicker oil all together.
Again my clutch wasn't coming on at all. The needle on my modified gauge was pegged over the red and the clutch had no drag on it at all. So I'm not worried about over driving the fan. And I'm not advocating that people take some readings on their clutch and automatically advance it 10*, which could put you in an over drive situation, but actually setting it to a specific temp which would yield different amounts of adjustment for different clutches.
As far as the electric fans, I don't see a need for it right now.
