Builds Family haulin' (1 Viewer)
Tapage I just want to make sure we're on the same page and that I'm not mis-interpreting you. I know you've been tweaking your diesel and you know this stuff well.
This timing page I found before when I started learning (still learning) more about tweaking my engine helped clarify what timing does to a diesel . Diesel Timing
What else have you done to your pump?
I'm not sure if we share the same tipe of pump .. but In my experience ..advance the timing of my IP don't lower the EGT .. but I do it at the same time as I increase the fuel settings.
Now I can blew my pyro if I want .. sure I have plenty of care each time that i push the skiny to the metal .. don't go over 1250 ..
But the mayor advantage that I get from advancing the timing it's the low end torque at hard start .. and that why I do .. due to my stock gearing and my auto tranny ..
Boots, Thanks again for the great thread. I've learned a ton just reading along.
weekly update
Glad you like it Jeff.
The vibs from the tires were getting worst so I decided to research some more balancing options. I'm still really drawn to the dynamic balancing idea so I looked at other media to put inside the tires that was still cheap. Unfortunately the options are limited and I decided to try out Zinc plated BBs. So in order to get the airsoft out and put in the bbs I needed to break down the tires. Being cheap and wanting to do it myself anyways I ended up buying some tire spoons and made a bead breaker. I didn't come up with the idea, just copied it from something I found online that mounts on the bottom of a hilift jack. It uses the holes on the jack base to line up and not slip off. I made the curved plated 3 inches tall and just traced the plate for the base size. I heated it up, bent it a little and then welded it together. It was 1/4" scrap I had laying around.
I first tried it out on the rear bumper on an old trailer tire I have laying around but it needed more weight so I moved to the front. Since I've got plenty of weight up front it worked well and popped the bead on a rusted steel trailer tire. I moved up to my 38s and I only had resistance with one, the other three let the bead pop right off. On the one I had resistance I used a rubber mallet to help persuade it off while under the weight of the bead breaker. This is how I placed it on the tire.
This is after a couple of cranks on the handle watching for any slipping or shifting.
I got out my new tire spoons and started playing on my rims. I tested them out on a steel rim to try and get the feel of them. On my first aluminum rim I bent the lip in two spots getting a feel for how to use them but by the second rim I started getting a better feel and on the third and fourth rim I had it down. I was trying to pull too much over the rim and found taking smaller bites worked much better.
I looked inside expecting to see the airsoft pellets broken up or damaged but I didn't. They held up just fine so that made me curious to if bbs were even going to work.
Well, I was this far so I might as well try them out and see if I get any change. I vacuumed the airsoft out and put in the bbs. I just poured the whole container into each tire ~20+ oz.
The other reason I wanted to get inside was to fix the leaky valve stems. Here's what one looked like.
The rubber on the old ones was cracking and in pour shape. I couldn't get replacement grommet at the place I bought the tire spoons at so I ended up getting 4 new ones. The new is on the left and the others are the old ones.
I used the starter fluid bead reseating method of flammable fun. No matter how many I did I still flinched every time the "controlled" ignition popped that bead back on the rim. On my second rim it would pop the bead back off the rim due to the vacuum created inside the tire. I did that a couple times with the same results. I then got my blow nozzle on my compressor, bumped the regulator to 100psi and got ready to play with fire again. Once the bead popped back on I grabbed my blow gun, put the nozzle in the valve stem hole and started to blow (no valves were inserted while reseating the bead). This put some pressure inside the tire basically equalizing the pressure and kept it from unseating the bead. The first time I had to tell my daughter to go sit on the step away from what I was doing before I lite it up. The second time she never came close.
I've only driven it this morning to work and the results are mixed. The bbs seem to help balance better while at speed but I still get some decend vibs around 40mph (part of my DW problem) and they don't do so well at those speeds around curves. I know I won't be satisfied with this so my initial thoughts are to take out the bbs and get the tires balanced traditionally. I think that because the tires are so wide dynamic balancing might not be the best choice. My choice of media could also be the problem and I've at least eliminated two materials. There are lots of other materials out there but not lots of funding to try them out.
The guy at the tire supply shop gave me some samples. These are Equal samples and problems they see.
This is counterbalance. They are glass balls.
I've tried out dynabeads on my last rig. I was getting vibs but my rims were a little bent and I could have had a bad rear pinion angle so I'm not sure the beads weren't working.
I got some tie-down tracks for a present last Christmas and thought I'd throw them in.
I put some right by the rear seat, on the sides like above, and one at the back. It was originally two tracks but I cut one up to give me a few more mounting choices.
I'll be helping out the Cruise the Woods this coming weekend so it'll be nice to be in the dirt.
I got some tie-down tracks for a present last christmas and thought I'd throw them in.
Two questions with these tie down tracks. If you don't mind, where did you get them? Secondly, it looks like they are attached with self tapping screws of some type instead of bolts with fender washers on the back. How do they attach, and how secure do you feel they are? I use a ratchet strap to secure my junk in the back while off-roading, which can obviously produce a ton of tension.
My intended use is the same as yours.
The kit came with both counter-sunk metal screws and counter-sunk fine threads with nylocks and fender washers. The screws are spaced every 6 inches apart and I used the fine threads on the sides and the close-to-seat mounts because I could get to the backside in those locations. I couldn't get to the backsides of the rear most bar and used the metal screws for it. I only put 4 in the rear bar because I wasn't sure if I wanted to cut that one and put a couple of bars in other places.
They have a website on one of the labels so I'll go out at lunch time and get that. I imagine it will have ratings on the website. I will test out the configuration this weekend as all I have is that spare tire racheted down. That seemed solid so far.
those tracks look like the tracks used in helicopters and airplanes for mounting seats and tie down rings. In our helicopters they are mounted with 10-32 screws but I don't know the load rating... Very handy and versatile.
The tracks are called Core-trax and here's the website: Core - Products
It doesn't talk about weight limits on the tracks but does talk about 500 lbs per load lock (accessories page).
I'll see if I can find any info on the instruction sheet that came with it.
weekly update
Took saturday off and drove out to TSF on friday night for the Cruise the Woods '08 event. I was assisting with a checkpoint. Planned on meeting up with DirtyGipsy to caravan to the camp ground. On the way out of Portland I put it in 3rd, locked the converter and gave it a little juice to get up the hill (traffic was too slow to go into overdrive) and really started getting some vibs from the rear tires. It was the worst I've ever felt and it wasn't going away. I exited a couple miles later because the vibs weren't going away and I couldn't find a speed/load that would reduce it. I thought maybe I had a ujoint going but I checked the ujoints, lugnuts, ubolts, leaf bolts, steering even though it was definitely coming from the back. After confirming there was nothing loose I got back on the road and just kept it easy and got this weird cyclical vib coming in and out. Just as I reached the exit road to meet up with Dirtgypsy he pulled up to the stop sign so I kept going straight and he pulled in behind me and we made it into camp. We went back out and got some firewood, made a fire and chatted for awhile. The next day we woke up early and got our instructions for the event and I followed another member to our checkpoint. We wheeled up the trail that the group would be coming down.
I didn't end up fitting under the tree.
While we waited I changed out my burned out headlight. We didn't have much to do and ended up closing down our checkpoint due to time constraints so we wheeled a trail on the way back to camp.
The event went well and I stayed another night in the hopes to do a little wheeling the next day. The group got up, got a few things taken care of and went on a couple trails. Dora's not a virgin anymore, she's been mounted.
Came up to the mini rock garden and had CreeperSleeper spot me. The throw for my doubler is off so I couldn't get it in stupid low but Dora did just fine. Here's a couple of shots on the garden.
P9280274.JPGg
https://lh3.googleusercontent.com/-nX_-7fV_9Vk/UPy_9gpgetI/AAAAAAAACds/G7Pu6sXbYTM/s800/P9280277.JPG/IMG]
[IMG]https://lh3.googleusercontent.com/-TazEgWLLmmk/UPy_-ilMtlI/AAAAAAAACd8/M-0UDaCcTcw/s800/P9280279.JPG
Up top on SaddleBack mountain.
On the way home I got the same vibs so I resolved to yank the tires and pull those BBs out of the tires that I just put in last week. After I got all that done I was curious and took it for a drive. Vibs gone! I took it on the freeway this morning up to 70mph and very little vib! So I'll be driving around without any balance. Don't get me wrong, they aren't glass smooth but have no where near the vibs I was getting before, it just feels like the vibs from the big lugs hitting the road with no thumper (Bambi reference) syndrome.
Let me say that the diesel performed GREAT! I filled up before the trip and came back home with 1/2 tank left. I never had to give it full thottle although mud will be different. So far I really enjoy this combo and look forward to getting out more often. Wheeling an auto is great, especially one that stays where you put it.
Took saturday off and drove out to TSF on friday night for the Cruise the Woods '08 event. I was assisting with a checkpoint. Planned on meeting up with DirtyGipsy to caravan to the camp ground. On the way out of Portland I put it in 3rd, locked the converter and gave it a little juice to get up the hill (traffic was too slow to go into overdrive) and really started getting some vibs from the rear tires. It was the worst I've ever felt and it wasn't going away. I exited a couple miles later because the vibs weren't going away and I couldn't find a speed/load that would reduce it. I thought maybe I had a ujoint going but I check the ujoints, lugnuts, ubolts, leaf bolts, steering even though it was definitely coming from the back. After confirming there was nothing loose I got back on the road and just kept it easy and got this weird cyclical vib coming in and out. Just as I reached the exit road to meet up with DirtyGipsy he pulled up to the stop sign so I kept going straight and he pulled in behind me and we made it into camp. We went back out and got some firewood, made a fire and chatted for awhile. The next day we woke up early and got our instructions for the event and I followed another member to our checkpoint. We wheeled up the trail that the group would be coming down.
Fellow member's FJ80
The event went well and I stayed another night in the hopes to do a little wheeling the next day. The group got up, got a few things taken care of and those left went on a couple trails. Dora's not a virgin anymore, she's been mounted.
Came up to the mini rock garden and had CreeperSleeper spot me. The throw for my doubler is off so I couldn't get it in stupid low but Dora did just fine. Here's a couple of shots on the garden. I'm going do a little picture whoring.
Up top on SaddleBack mountain (I think)
If you are interested in other pics from the trip you can see them here starting with post 39: Cruisn' The Woods 2008
Glad to hear the trip went well Mike... I wish I could have been there. Told you wheelin with an auto is like cheating. :D
Yeah I know it's a little small but it's better than nothing. The boggers I have are on 8 lug rims and if I decide to swap in the 14bolt those will be ready as spares. I'll just have to get 4 other tires and rims :rolleyes:
Hey, that 14bolt is a C&C 14 bolt (measures ~63" WMS to WMS) I assume you plan to run a D60 front? Youll need to shorten the front 60 if you do. Have you given this much thought? Im doing this on my 40 now and it seems that maybe 62" up front will fit right with the stock perches. idk, i like the idea but its gonna be more money and alot more work. Whats your plan for this?
I'd narrow the 14 bolt and get adapters for the front to run 8 lug stuff. I need to double check what ratio the 14bolt is (I believe it's 4.10), do some actual measurements to see if I can make it offset (something about just shortening the long side and running two short shafts) and to see what width I'd need to get close to the front with the adapters. Since there are two hub options for the 14bolt that gives me more options for narrowing. Definitely would need to convert to disc brakes and do a little shaving. I would also plan to run a Detroit in it. If I swap out the rear axle I'd only do it for an upgrade to something stronger and full floating.
The idea is to set it up (locker doesn't count cause I have to buy one for my rear now) for a similar price as buying polys. Still debating whether I really need it or not. I could sell my current axle and recover some of the cost. For now I'm just going to run the cruiser axle and get to know Dora off road.
If I go 8 lug I'll most likely step up to 17" rims since there is decent tire selection for them.
As for shaving I meant the diff for a little more clearance.
So I just bought an FJ62...
...If I can find a step van, and drop them both off at your house - how much and how long for you to do my diesel conversion?!?!?! :D
