Build Family haulin'
42s and some double beadlocks. :) 13/64 for the drill bit. Makes a big difference. Make sure to run a decent cooler or you might run into cavitation problems. Be careful when you pull the restrictor, the spring wants to pop outta there and dont loose the bushing! Ask me how I know!
Dude, you know you want a buggy...................:p
Save the 60 as it is, wheel it and go for a buggy!!!
I bet Mark and LT would be able to build an awesome chassis for you.
I have some 39.5s for sale. :)
Ohh Lord .. !
Those 42" sure math with 1 Ton axles ..
Boots ... thanks for the pics .. great, big time, yes I'm running my factory Toyota Steering box and yes .. too my Tencha is as normal ( joke for Aussies ) world driven .. LHD.
BTW I forgot .. Boots, why not disconecting the wastegate and take a test run .. just to know if you see ( blocking the port at the compresor ) more than 18 PSI .. this discard the wastergate adjusting failure.
My actuator and linkage is behind the turbo so getting to it won't be a five minute job. I do plan on holding the gate shut to test that out like you suggested.
I have a bunch of stuff in front of it now and the starter is in the way from underneath. But I'll figure something out. (Time for an oil filter relocator to make removing that 4" elbow easier)
Not easy .. maybe as dificult as I have on my both Turbo Cruisers .. I notice in Tencha that have the wastegate in the same place ( in between the Turbo and the block ) that the heat make the spring and the hole wastegate system more soft ..
What I do in Marilu ( learing in the process ) it's run a halmarks boost controler ( blocker type ) it allow me to route and block the comrpesor signal ( boost ) that goes to the wastegate, before it reach the wastegate and try to open it ..
So I place the wastega in much more comfi place ..
main.php
Hey, I dont know that the intake plate needs 30+ lbs of torque. The factory torque spec for it is 18ft/lbs. Just a fyi. Also, on the valve side of the intake plate, you may want to consider using some form of thread locker to prevent blow-by when pressurized. Have you pressure tested all your intake plumbing? with the intercooler and all, it wouldnt be crazy to have a leak some where at a joint or hose connection. You could disconnect the hose to the top of the intake plate and plug the system and add a valve stem and check to see if you cant hear the leak....just an idea.
weekly update
I had a bit of a challenge finding long bolts for the intake plate. I finally found some at tacoma screw. The long ones were 8mm x 1.25 x 80. The only flange head they had was in the 10.9 class and the heads are actually bigger so I get a little more surface area for clamping. I wrapped them with teflon tape and tighten them up. This time none of the screws felt like they were stretching so I think it was a good idea to replace them since I had to open it up.
I also found a plug for the wastegate signal line. So with the actuator disconnected, the line plugged and the intake plate tightened up I still have a leak. Yup, the gauge even bounces more but I did see 1 psi increase. I'll just keep plugging away at it and pressurizing the system may be the best bet.
My wife and kids have been pretty good about the whole project but even I needed a quick break so we headed to the beach to have some famliy time. There are certain beaches here in oregon you can drive on so it was a good chance to see if I float or sink, on the sand of course.
We found a great place out passed Astoria called Warrington OR. It's where the columbia river opens into the pacific ocean. We drove around and found some beach access. We were the only ones on this beach and the water was shallow with a gradual decline being great for kids to splash around. I motored around in 2WD the whole time.
We spent a couple of hours there and had lunch. The wind started to pick up so we packed up and went exploring some more. We found another beach with access and drove out there. This one had more people on it with all kinds of street vehicles on it. We got a few waves from other toyota's but the one I was impressed with was a semi on the beach!
This is my favorite pic of that day.
I even put a small video together from a couple of clips.
YouTube - Wheeling in Warrington OR
testing!
The next day I had the chance to do a little wheeling so I met a friend and we headed out around Estacada OR. We planned on a light trip to test things out. We got in and found a good obstacle to try. It had a vertical face of about 3ft.
I bumped up against it and just added a little more right foot and the front end popped right up.
I lightly bumped it a couple of times to see if the back would pop up but since I have no locker out back I'd end up spinning a tire and loosing traction. This is when I heard a crunching sound come from the rear end. I'll be needing a new tail light. :rolleyes:
I decided to give another harder bump with more throttle and I found my weak link. My homemade front driveshaft snapped. If I would have been able to keep all the splines I think it would have held up but this broke right passed the weld. Talking to my friend I think he came up with a good idea and it doesn't look like I'll need all the slip I built into this shaft so I'll keep this female and get another male to replace my broken one. I'll have to lengthen the tube again.
I took the shaft off so as not to run the risk of it binding and blowing out my Tcase. My buddy asked if I wanted to park it and wheel with him but I told him I'll just play around in 2WD. So we went exploring and I followed him around. There were a couple of spots I needed a yank if I couldn't bump over an obstacle but I still had fun. He was impressed on all the places I could get to in 2WD and I was impressed too since it's an open rear end. Those tires just kept on biting.
We just left the strap on the front after the first yank to make it easier. We found some mud pits (more like deep puddles) to play in.
And then we found a nice rocky climb to play on. I did park mine and scout/ride along with him on this section. It will be pretty challenging when it gets wet and we'll definitely be coming back to this one. So we wheeled up in his rig and got to the top and it was the top of this mountain with a fantastic view!
These are two shots looking down at different spots.
Second incline section
After that we headed back down the mountain to call it a day. So for carnage I broke a front shaft, got a few more scratches (they'll buff out :lol:), and cracked my rear tail light. On his rig he busted a lower shock mount on his front axle. Good testing day and good to re-energize for building the last few things to pound around in it.
I was turning onto my street to my place (10 houses from mine!) and a cop two cars back and in the other lane jumped over and pulled me over. I got the ol' fender flares and mud flaps warning so it looks like that'll be my project next week. Mud flaps will be easy but flares might be a little more difficult. I might just see if I can get by with flaps for a while.
I also slapped together another little video from clips.
YouTube - Wheeling in Estacada OR 9-2009
Wow, where is that in Estacada? I'd like to check that out. Looks like you guys had a good time. I might also have a solution to your front driveline problem depending on the length you need. :) Also looks like you'll need to come over so we can bend you up some protection for your rear.
Love that Diesel sound!!!
We're wanting to go out there and map stuff out at least once a month and I think we're wanting to go more so I'll let you know when we go next. There were a couple of posted no-motor vehicle signs on some of the trails so we stayed off of those but these were still good.
I really do need to start bending tube so we'll get together soon and I'm very interested in your front driveshaft :D. Even the rear if it becomes available and things fit up. What size dies do you have so I can pick up some tube?
I'm going to be down for awhile (currently pulling my axles) so I probably wont be able to make it out on the next run you guys make out there. My current driveshafts are spoken for but I had a nice one that driveline tech made for me that I was using for a spare. I'll measure for it for you tonight extended and in all the way. It's all yours if it'll fit...
Just one die right now... 1.75.
You can always ride along and be photo behach :grinpimp:
1.75 is the size I was hoping for. Do you have a decent place to get tube on your side? The steel yard on Columbia Blvd only carries 1.75 in .095 wall and I'd like to aim for .120 wall. The one out in clackamas didn't have any 1.75 .120 wall.
Are you taking pics of your tear down? We always like pics!
Yep, I'll be taking some pics along the way... not sure I could compare to this thread but I'll do my best.
No great deals on this side either. I usually get my stuff through Forest Grove Iron but they usually dont stock much tubing either. They can have what you need within a couple days though. I got my .120 through special order with the steel yard... I dont think I'll ever use them for tubing again. Sometimes they have good deals in their "overstock" for flat bar and what not but overall I'm not impressed with them.
Looks like it works good. Nice and flexy (and sexy) . Thanks for the off road porn. Your diesel is too cool.
Thanks for the pics .. the story but the best sure, the video ! thanks .. sound like a good baby this 4BT .. so you found your leak . ?
Nope, I'm still looking for it and I think I had a couple so while I've fixed some others are showing up. If all I need is more fuel I'll feel pretty stupid but that fluttering boost gauge seems to indicate I haven't found them all yet. So I still feel like I haven't really seen what this engine can do yet from free power although I test it out everytime I get on the freeway :D.
I saw that you already disconect your wastegate .. but not if you see more boost .. and together if you adjust to more fuel if you get more boost .. ?
how are your EGT's .. ?
The 4BT use a butterfly at the intake or any other sort of blokage that can cause a turbo spike .. ?
