Fall Crawl Truck Preps (2 Viewers)
Stumpalama
Forum Junkie
NOVA
Website
www.capitallandcruiserclub.org
What are you doing to get your rig ready for Fall Crawl?
Got most of the tough work done this weekend. Lots of cutting, grinding, assembling, disassembling, assembling again.
Just waiting on some parts to finish the job. A flat pitman arm, DOM relay rod, and fittings and hose for the power steering pump to box connection. Apparently my set-up requires a custom hose since the pump has a different fitting (17mm) from the FJ62 box (16mm). I also have to get the steering stub shaft machined to fit a bearing and the 3/4 DD u-joint. Yet another unique requirement because my truck is a late model 40. Yipee.
I WILL be ready... Oh, I also ordered my new wheels and tires
This is becoming an expensive weekend.
Sealed fuel tank!
Cleaned carb!
Replace plugs!
Installed break line lock!
LIFE • HEALTH • PROSPERITY
Sealed fuel tank!
Cleaned carb!
Replace plugs!
I think you may be in danger of setting personal best for consecutive wheeling days with this truck...
No threat there's only 2 days of wheeling for the Fall Crawl!
Most of my work was on my Geto Trailer!
Lights & wiring.
Brake & brake away Wiring.
Tie downs
Safty chains.
New 2 5/16 Tongue
I sat down on my Hilux tailgate and drank some beers. Does that count?
Lights & wiring.
Tie downs
Safty chains.
New 2 5/8 Tongue
I have too many 2" drop ball hitches if someone is in need. I have a 6500lb with a 2 15/16" ball and a 15000lb with a 2 15/16" ball.
My rig has been sitting....
Madelyns plastic jeep has been getting the attention..
New 18ah 12v primary battery
Twin 4.5ah 6v batteries
18v boost button on the dash
New plug n play charging circuit
Smart 2/6/10 amp charger
Still to do before Fall Crawl...
Titan 550 motors
19 tooth 32 pitch pinion gears
5 fin aluminum heatsinks
Titan 550 motors
You better get cracking. It's right around the corner. Sounds like Madelyn's jeep is coming together!
Stump how are the upgrades coming along.
Getting there. Just need to hook up the hi pressures hose, attach the relay rod and steering shaft and get tstub shaft back from the machinist.
I will be ready.
Rear bumper and skid plate on.
