Thats good news the intake was clean and coolant level in the correct range.I kinda agree on the failing cat. 195k is about when the cats on my old Tundra gave up but they didn’t give me the drivability issues that I’m having now.
I do remember seeing a post here about the AI foam filter disintegrating, I haven’t done anything to address that and I’m not sure if @2001LC knew about that problem when he did all the work to this truck. Need to find the thread and have a look…
I did remove the intake tube to inspect and clean. While the MAF sensor obviously was dirty (tip in immediately improved after cleaning) the rest of the tube and throttle body wasn’t bad at all. The OEM filter was doing its job and keeping the clean side clean.
Overflow levels are good hot and cold, coolant looks good.
If battery was disconnected when you cleaned the MAF, it takes several drive cycles for the ECU learn new parameters. If battery wasn’t disconnected- it may take a bit longer
Is there anyone here around Northern Wyoming or the Black Hills that has TS and would be willing to help a brother out?
First report of CEL.
