Ok this is my second test and Im perplexed by the results. After the first test I had the Toyota tech adjust my carb and he said that I was almost there but that recommended a cat to get me there. so here's the results from test 1
High speed
HC. CO
Standard 220. 1.20
Reading 89. 1.43
Result. Pass. Fail
Idle test
HC. CO
Standard. 220. 1.20
Reading. 326. 5.69
Result. Fail. Fail
Had carb adjusted and added a bottle of guaranteed to pass. Ran thru a full tank of gas and took her to get tested after driving for about 1 hour. Results from test 2
High speed
HC. CO
StAndard. 220. 1.20
Reading. 105. .96
Result. Pass. Pass
Idle test
HC. CO
Standard. 220. 1.20
Reading. 798. .61
Result. FAIL. Pass
So what would cause the HC's to skyrocket and how can I fix it? Think there is still too much carb cleaner in the system? As an added note the cruiser is originally from Australia so doesn't have any US emissions.
High speed
HC. CO
Standard 220. 1.20
Reading 89. 1.43
Result. Pass. Fail
Idle test
HC. CO
Standard. 220. 1.20
Reading. 326. 5.69
Result. Fail. Fail
High speed
HC. CO
StAndard. 220. 1.20
Reading. 105. .96
Result. Pass. Pass
Idle test
HC. CO
Standard. 220. 1.20
Reading. 798. .61
Result. FAIL. Pass
