- Joined
- Sep 9, 2004
- Threads
- 200
- Messages
- 12,472
- Location
- Boise - Idaho
- Website
- www.snlandcruisers.com
- Thread starter
- #101
Only cause you are a lover bro.
Cheers
Cheers
I like the press addition. It was very awkward trying to hold control arms and keep the press going straight. And at the time cringing waiting for the "bang" when the bushing lets loose.Here is some pics finally!
I actually am digging the steps/sliders. makes roof access way easy.
Had to paint this, got to represent!
The GM tre reamer I have been waiting on
My new and improved RLCA
I got a little artsy fartsy with it, notching the angle iron to wrap up and around the rod end.
Front Fox 2.0
Rears, ya I got the guard on them, have to on an 80!
old vs new bushing
Chevy brake light switch installed, only using for TCC at this time but other prongs can be used to set up cruise control
pile o' Toyota parts
All this stuff has to get installed in the next 2-weeks!
The arbor I made for pressing out bushings
Cheers
^^ HA!
I build most of my presses and I am the same way... Once they start getting in a bind and really start to push... I put on my safety glasses, cover my nuts and chest and then relax once the press is made.. HA!
I build my stuff with a 4:1 safety factor... BUT!! YA NEVER KNOW!
J
I so hear that, always worried about the face and balls! I wear safety googles and a face shield and put on gear too. Still sketchy. Last year I had a seized axle in a housing on my Pinzgauer. That is what we busted the arbor with. I took it to a local guy I know with a 100ton press after the 20ton was not getting it done. He put it in there, I hid behind a steel post and he went for it. Took 60tons but it came out rather than busting. Really dislike that kind of stuff. No probs just pressing in a new bushing or bearing or whatever but when something is seized and you are trying to get it out, it is sketchy.
Have not had much chance to mess with the bumper yet. That is coming up though after the cut & turn.
Cheers
are the OME ones in backwards? If you didn't install them might be worth double checking.
The caster bushings. they can be installed in reverse, and cause the caster to go the other way.
I lifted 4" and needed 7° correction.
You 1st page pics are all missing or the links are no longer good.
Just letting you know. I would like to see them.
