- Thread starter
- #21
Bed mounts and bumpers wanted to occupy the same space, but I'm mostly happy with how this turned out. Those big holes are for the combo LED tail lights and I'll have backup and rock lights in the open space next to the rear cross member.
I welded 3/4" square tubing on to the door frame I cut from hard top side panels. I need to widen the channel, but this is how the soft top will connect to the door frame, close to FST style.
I REALLY wanted a snorkel on the left side of the truck and since I'm running a Vintage Air heater I don't need the heater intake vent. So I cut some 14ga and took 3.5" exhaust tube and went to town. Turned out pretty slick.
I need to get one of the inside pipes bent at the exhaust shop and make a mount for the filter but the intake for the motor is pretty much done.
I'm still working on how the radiator and coolers are all going to mount. I think everything will fit as it is now, but it's VERY tight up front and I still need to stick a power steering cooler somewhere. I used some 3/8" allthread and cage tabs to brace the radiator on each side. Passenger side is easy but the PS gearbox and pump are making the driver side tight.
I need to finish up the driver side 3/4" square tubes, weld caps on the half doors and then finish weld all of the cage tubes. I cut a 14ga piece to cover up the giant hole in the dash and I'll cut holes in that for the HVAC controls and the radio head. Once this is done I'll be cleaning everything up and getting ready to paint it. I planned it out and should be able to get it painted and wired by the time kid two shows up in October....should be able to.
The wheels and tires on the front are what I plan on running to start, 315/70/17 on FJ cruiser steel wheels. I have 4.10 gears in the axles now, but would like to go 4.56 or 4.88 and 37" tires in the future which will probably require a spring over in the rear at least....will see.
