Hi all,
Stump, since you are set on a full-floater (to do away with the c-clips) and need to stay with an off-set rear diff, I think using a 80 Series rear axle assembly might be the way to roll (pun intended!
They are available relatively cheap, and you might be able to use your existing Air Locker in the 80 diff (can't quite remember the differences.) And this will be stock Toyota parts, not a mix of factory and aftermarket.
Regards,
Alan
Regards,
Alan
time and commensurate reduction in time and frustration pulling an entire axle apart to replace a broken shaft.
