Alan,
I agree that would be cheaper $$-wise to leave it alone and carry spare axles, but where is the fun in that?
A little background on my rationale for this:
This Fall, I broke a stock SF on a trail and the subsequent 6 hours of pain that ensued is something I would like to avoid in the future. I have rear disks, which saved my ass, and got me the few miles back to camp.
However, I am glad I didn't attempt to fix this on the trail. The short side axle broke in a spiral pattern at the splines right inside the ARB actuator assembly, under the bearing cap area. When I attempted to pull the c-clip, the axle stub was mushroomed enough and the splines deformed enough to prevent the stub from moving enough to allow the c-clip to drop out, much less remove the splined stub.
So, off came both axles, out came the 3rd and the beating commenced. I beat the ever living sh!t out of that stub to remove it. The axle flopping around in the ARB wallowed out the sleeve and I now need to spend $$ and time to pull the 3rd again and replace that cap since it is weakened and will eventually fail (Vince Dooley from Forge Specialties, who helped me with the fix at camp and looked at the damage recommended replacing the cap). I also bent the caliper mount bracket and sheered one brake pin and bent the other; fortunately these were stocked at the local Autozone. I hadn't considered stocking spare brake pins in my trail kit, they are there now though.
Oh, and semi-float Chromoly axles are no longer available.
The sole source for semi-float chromoly axles, Poly Performance, no longer offers them.
Thus my decision to pursue a FF solution. In short, I need stronger rear inner axles to handle the 37" tires and short of a custom axle/D60, this is the only viable solution I have come up with. I am certainly open to other solutions, if there are any out there.
I plan to use lcwizard's FF bracket with used spindles and hubs, FJ60 calipers and rotors and Nitro axles. The parts will run me just north of $1000 with new bearings, calipers and rotors. It isn't cheap, but my mentality here is you've got to pay to play and the peace of mind of having axles that can handle the stress and the reduced impact of a broken axle are appealing. Even if I had to pull the 3rd to remove a stub again, I could leave the wheels on, just pull the inners and remove the 3rd. The cool factor cannot be discounted either, of course.
Notice the beers in the hand of the guy to the left of the photo. Another benefit of the camp fix.
Cheers,
Stump
