- Thread starter
- #121
Alright, charge light for the alt is wired, (to L on alt connector, then switched 12v) so the alternator wiring should be finished. One step closer to getting this running
Ok that's what I have going on in mine already, just wanted to verify this particular end of the White blue remains unused. Once I unwrap this side of the harness I'll put it out of the way as well.I capped the White blue wire that went to the alt and tucked/taped into the harness and connected the white wire to the batt with a fusible link. I added a wire from the alts sensing terminal to an idiot light on the dash.
So you cleaned/inspected the bulb sockets and added a good ground wire. Use a VOM to see if the socked is getting power - could be a broken wire or a bad connection in a plug up the line.
Does your horn work? It's a little fuzzy but I remember some surprising links between lights and other parts of the electrical system. Like everyone else will tell you, check your grounds. Also, the dimmer I believe is technically called a "rheostat". On my '78, I spent 2 and a half hours trying to get my instrument lights to illuminate, and turns out I just needed to turn the headlight pull clockwise. I forgot that our fancy vehicles had dimmable interior lights. By doing that, you may give more power to the lights, which could help.
That was me!
That was me!
Glad it helped someone else. It was off of my colleagues '75.
He omitted it and it solved some demons. YMMV.
