There's something up with my glow system. Thought it was just a corroded wire, but it looks like this will require a little work to find out where the problem is. I'm not great with electronics...
Anyhow, I have disconnected the glow plug plate and used ether three times to get er started for a few times where I have needed the truck. Not intending on using ether every day for an extended period of time, but I do have a couple of questions about ether use:
1) If I do this a few more times, will I cause any long term damage to the motor? I know that using ether is not the best...
2) Is there any particular technique I shout be using? I've had my girlfriend do as short a spray as possible (.5 second) directly into the intake off of the air filter while I'm turning the engine over.
3) Is there any other way of safely starting the truck without the glow system? My block heater also is not working. I can't get an oil pan heater where I am at the moment, but I have two battery heaters that I'm going to wrap around the oil pan and see if that will help with a cold start.
It's not that cold where I am at the moment - gets down to around 8-10 degrees Celsius in the morning. Thanks for any feedback.
