Builds Engr 88 Pickup - 22RE Megasquirt turbo build
Eastern Iowa
I picked this truck up 5 years ago in Wisconsin - rust free from AZ, for $2,200.
Slowly bringing it back from neglect
black interior
black carpet
dynamat
door panels
lots of wiring
lined cab
95 4runner bucket seats
V6 brake booster
A1 Cardone Ultra premium V6 calipers
OEM wheel bearings and seals
EBC blank rotors
EBC green stuff pads
O'reilly CVs
OEM power steering installed
front main seal
windshield
marlin shifter cup
rebuilt hubs
valve lash
plugs
fluids
OEM thermostat
OEM radiator cap
OEM clutch master cyl
OEM clutch slave cyl
side mirror
rear pinion seal
frame paint
Fall 2018
Bilstein shocks
LCE Header
Homemade 2.25" stainless exhaust
Magnaflow 11245 muffler
Bosch o2 sensor
Viair OBA 400C compressor 2.5 gal tank
Yukon rear zip locker
31x10.5 Cooper STT Pro
Spring 2019
4.7 marlin competition gears
Aisin pressure plate
Luk flywheel
Secco clutch
Pilot bearing
Clutch release bearing
Main seal
OEM distributor cap
OEM distributor rotor
Honda Odyssey washer spray nozzles
WIX fuel filter
Summer 2019
Parking brake cable
Crank arms
Rear wheel bearings and seals
Drums
Shoes
Hardware
Summer 2021
All new ball joints, tie rods, steering components
33s from my 80 series
Spring, Summer, Fall, Winter 2022, Spring, Summer 2023
Engine build:
Bearings - King 0.030 under. CR4129AM0.75, 506AM0.25, TW 234AM
Rods - Eagle forged H beam CRS5819T3D
Pistons - 22RE Performance 4032 forged - 0.020 over
Rings - Hastings - gapped to 0.027/0.028
Head Gasket - Cometic MLS C14086-040
Head - 22RE Performance Stage 4 CNC port machined
Cam - 22RE Performance Turbo cam
Oil pump - Aisin OPT054
Water pump - NPW PT T-67
Timing Chain - OSK 22RE Perf
Timing Cover - 22RE Perf
Head bolts - ARP 203-4201
Freeze plugs - 22RE Perf
Dipstick - OEM 1530135020, tube 1145235010
Plug gallery kit - 22RE Perf
IAC hoses - 2223-35010, 2223-435010
Throttle body hoses - 16264-35012, 16267-35010, 16281-35010
Oil pressure sending unit - 83520-55011
Coolant temp gauge - 83420-20020
Coolant temp ECU - 89422-12010
Rocker arms - 13801-35010
Rocker nut and screw - 90179-08049, 90913-05019
Packing, Dust proof - 1912715021
Distributor Rotor - 19102-73021
Distributor Cap - 19101-35180
Ignition Coil -
Spark Plug Wire Set - 9091929055
Cooling
Hoses - Dayco 71262 upper. Gates 21033 lower
Radiator - CSF 2306
Thermostat - 90916-03078
Fan - SPAL 16" puller
ECU - Megasquirt PNP Gen 2
Turbo - Garrett GBC22-350 44mm
BOV - Tial Q 50mm 11psi spring
Injectors - Five-0 Black Ops 550cc high impedence
Fuel Pump - Walbro F90000274
Fuel pressure regulator - Aeromotive 13129
Exh manifold - home made
CAC - Volkswagen Passat 2000 1.8T by Majesty
Brackets - powder coated
Alternator - Jaguar XJ6 Denso 2100406
2013
1628141
2023
2024
Why did you abandon the PCV? There really isn't any reason, performance wise, to ditch it.
Oil carryover from blowby coating the intake and throttle. Closed crankcase is for emissions regs
the cab is finally leak free after the new windshield and some spray bottle testing under the fenders - Newly caulked seams and it passes a pressure washer and thunderstorm test.
Dynamat xtreme and black stock interiors carpet are going in along with finally putting on the door panels.
Still need to dynamat and install the door panels.
Axle is torn down and slowly being cleaned before chopping and welding.
Butyl tape and 3mil drop cloth. Door panels are finally on and the interior is done.
Next up is welding a new 2.25" exhaust and something with this axle....
Finally giving in to fixing all of the exhaust leaks... On the plus side none of the bolts broke.. because every nut was almost hand tight.
The plan of replacing a few gaskets turned into an LCE header, desmog, o2 and a stainless tig welding project. Waiting for UPS
The biggest challenge is getting the new nuts properly torqued on the studs in the head. They usually just pull or strip out. And it's always the last one by the master cylinder, the hardest to reach and drill out.
Removed and chased
Wet cyl 4 is degreaser
Chase them all you want, they'll still strip out and ruin your day sometimes. Throw away all the old rusty studs, get new ones (OEM only).
Any time I had one of those heads off, my SOP was to go ahead and Helicoil them all.
Just went through this. What a miserable POS the 22re head is. Luckily it was on the floor of my shop. Had to helicoil the last 3 stud holes. On two of them I had to drill them out deeper and use longer bolts because the factory studs pulled the helicoils out. Fun day...
The holes are still smaller than a timesert/keensert, though, so if/when I have to do it again I can use one of those.
