thanks for linking this thread
@ntsaint
guys, i also have a 2006 - but it's an LX470 ~135K on the odo.
i have had a stalling issue as well.....not in extreme heat the first couple of times either, however, the last week, it has done it 3-4 times....mind you, all of my issues have been at various temps and gas levels....
it happens most recently when driving for a nit...start and stop and 10-15 miles to and from work....
i will pull up at work or home and put in neutral or park and sit at idle while on phone....then all of a sudden the rpm's start "hunting" and eventually shuddering a bit and it stalls. it hasnt always thrown a CEL/codes...however, once about 6 months ago it did. code was cylinder misfire 2-4-6-8 and i replaced all the coils....
fast forward to 10 days ago and scorching heat and humidity it does it again, no codes tho....towed in to buddies shop and they cant get it to replicate...
picked truck up tuesday and drove home, idle for 2 minutes and vuala....rpm searching and stalled....threw codes again this time...
left bank lean, multiple cylinder misfire, 2-4-6-8 misfire....
i have a new fuel pump for it, and also have 8 new denso coils and some new plugs to install since the coils are going in....will update after it is all done, just wanted to share my similar story and findings as well....happy to (hopefully) have found the issue (pump)
