Repeated from HDC Clubhouse build thread
need some advice on what to get to wire and control my elockers. I am using two FZJ80 lockers front and rear in an FJ40 (with a full float rear axle). I was thinking of using an FZJ80 setup, but from the research I did the front High pinion diff has a different connector. I think the tacoma uses the same std pinon setup as the FZJ80, so maybe two Tacoma Harness and ECU. I have seen some people use 12 Volt Guy's or inchworm setup with success, I am bit to go that direction though because they do not use relay to cut off power with feedback control, and relay on the actuator protection features. I have also seen people build there own, and I know I could do that, but I doubt it would have toyota reliability, I can already see a solder joint failing when I am stuck in the mud.[/QUOTE]
