^^ Matt, your rig is a beast! Give me more torque.
Yep not bad almost double yours so I suspect a well built 1FZ has a lot more to offer. I'm sure you have more than 4 main bearings holding the crank up.
Well no FedEx box today at the office, so it will not be this weekend. Also will be wheeling up in Tahoe next mid-week and weekend, so not that one either...may try do do the install during after-hours the following week, but that usually does not sit well with the family.
Have read some about the LandTank MAF, but not sure if I am ready at this point, or if that would complicate things with the current rich fuel dumping I have at 4000+ rpm. Need to find a local tuner who can crack into the ECM code and perhaps tweak the fuel maps via the OBD II, or look at a piggyback to do fuel management via the PC.
Also for those looking for the Dyno Logs, here are two.
http://emspowered.com/productdevelo...s/supercharged/CycloSteve_before_exhaust1.jpg
http://emspowered.com/productdevelo...s/supercharged/CycloSteve_before_exhaust2.jpg
What is the AFR that people need to run for this motor at WOT and at idle?
It will be interesting to see someone crack the MAPs through the OBDII port.
It's not?![]()
Thanks for sharing. Do you know what the advertised crank HP/TQ numbers are for the blower at 6 psi?
I regularly flog the **** out of my rig--pushing 4200-4600 rpm for sustained time periods--mainly going up passes and other "troublesome" terrain where the 1FZ just falters with stock gears and big tires.
I did the Eisenhower Pass in Colorado pushing 4500 rpms for almost 8 minutes keeping a sustained speed of almost 67 mph (normally aspirated).
I did that same run at 3200rpms at a whopping 20 to 25 MPH , while helping kill all the bugs alone Rt 70 with the nice sooty diesel cloud pouring from my "90hp of Fury" 3B tuned for sea level
I did see 60+ mph , on the way down the other side![]()
Wut? Does that mean I should stop using the rev limiter as a audiable shift light?!? (Anybody who has wheeled with me know that I'm not kidding... Especially when I was on thoseToyos!)
The issue is that I am not sure that anyone can actually do the OBDII type of "flash" to our trucks for fuel and timing. You see so many other manufacturers where flashing a new program is common; it would be nice to find such a plug-and-play solution, or someone who has cracked Mr. T's code for customization for us too.
My daily-driver is an Audi, where there are multiple tuners who offer off-the-shelf solutions and custom programming, some of which even have OBDII programmers you can purchase and re-flash different tunes to your heart's desire (including back to stock for inspection purposes). Part of the idea behind OBDII was the ability for the manufacturer to be able to fix issues with the fuel and other systems via the port...which in theory opens the door for tuners to do the same with a performance-bent view.
I certainly will be looking to the Toyota community to see if there may be some cross-over knowledge from perhaps the folks tuning Supra's, etc. which can be applied to our applications.
