I imagine you were able to use the original radio brackets as well.
12volt electrical system in that truck right?For the '97 FZJ70, we went with a single DIN floating display unit. It is non-stock in appearance, but that was not a strong consideration. This Cruiser is my bride's. As such, it has all the functions she wants from the system plus a display screen large enough for convenient viewing.
As can be seen in the picture, it covers a portion of the drivers side AC vent but not enough that we have noticed.
Yes. The '97 has the 1FZ engine so she is 12v.12volt electrical system in that truck right?
So I have a step down converter but it is always hot and lives in the engine bay. It is pretty big and old. They seem to have shrunk in form factor a bit. You could likely integrate one of these (link below) right behind the 12v stereo and still use the original plugs (if they are still in there) using one of Crutchfield's install kits. Then any 12v stereo will work. I did not shop for 24v stereos at all since I already have the converter installed.Yes. The '97 has the 1FZ engine so she is 12v.
The other 70s might be a confusing factor here because that is what you have seen me with. The '86 BJ70s started life with 3B engines so they have 24v systems. They also need new stereos; but with 24v systems, they will present challenges (i.e., cost in $ and integration) so they are on the list for later.
