Dragging rear caliper (2 Viewers)
PNW
Website
lexusgxor.com
I replaced my pads, rotors, and full brake fluid flush about a year ago. Calipers are all stock and vehicle is at around 90k miles.
I noticed last Friday after a drive to my cabin I heard a noise at arrival from right rear when backing up and discovered that wheel was pretty hot. Thermal gun showed it around 450 degrees compared to around 100-125 for the other rotors.
I have far less tools at my cabin than my house for full size rigs so had to make do with what I had before I could run into town. Tools I have are more biased toward motorsports gear.
Caliper comes off fine and compresses easily. No indication of a collapsed line either. Slide pins looked like they could use some extra lube but again do move and brake hardware didn't have abnormal buildup.
No drag of parking brake drums nor any play or sounds that there are any bearing problems.
I then took another test drive... temp is now about 100 degrees lower at around 350.
Next day I get a few things from town but pick up some caliper lube.
I take things apart again and exercise the piston a few times with a c-clamp to make sure it doesn't pop out. I then thoroughly wire brush off any residue from hardware and lube up pins.
Now temp is down another 100 degrees to around 200-250. On another drive it seemed even lower so may have temporarily freed up something but still needs to be addressed.
Unless there is something upstream at the brake valve body I assume the caliper has some minor scoring/corrosion or that the seal within the caliper to help retract is worn out or deformed.
I'm not opposed to a rebuild but I think I will get a new caliper this time and use the old one as a learning tool of procedure when I need to do the other. I know rebuild kits are dirt cheap compared to a new replacement but I'm fine with that in this case if I get some knowledge out of it. Honestly never had to replace or rebuild calipers on any of my vehicles over the years. I guess I was lucky.
Thoughts, Comments, Criticisms all appreciated :)
NAPA reman calipers are just fine. About $97 per side with a lifetime warranty. They are OEM Toyota calipers that have been rebuilt and coated black. My local NAPA stocks them. I'm running them on the front and rear of my rig - no issues.
I grabbed a new one from a local dealer for $272, but a quality reman unit should be 99% as good.
My reae passenger side was bad. Its not uncommon with the GX and in general it's quite the heavy vehicle for the brake system it has.
Hoping I don't have to do the same on the 4runner.
Thanks for feedback both of you!!!
@Rednexus - Good to know on NAPA option… I will definitely keep that in mind in future as there is a NAPA in town.
I ordered a new OEM this go around from Bell Lexus @ $172
Side note… not often out sitting with my GX to hear the evaporative emissions pump kick on after a few hours..just heard it humming away.
Yea, I should have ordered mine ended up hitting the closest dealership.
My local NAPA can get Koyo wheel bearings and 555 tie rod ends, ball joints, etc. They are literally the only aftermarket chain parts place that bothers to stock name-brand parts from Japan for our rigs. Granted they are more expensive than buying online, but if you need a wheel bearing the next day, it's nice to be able to get a legit Japanese-made one.
What's it like when the wheel is off the ground and you try spinning the tire. Does it spin freely? Or is there some grinding?
I know it's now after the fact, but maybe a pebble or something got caught in the caliber?
But looking at your temps, hummm. Taking it apart and reassembling it, would remove anything like that.
Hope you get it sorted out!
Spins freely.. It is probably considered minor drag in comparison to what it could be but still generates heat. Definitely not debris related after what I have done so far.
Mine did not make any noise until the pads were gone.
I’ll probably start doing more rotor thermal checks in the future on all my cars. I’ve typically only done them once or twice a year in the past. It may catch things earlier before I am out on the road.
  • Like
Reactions: r2m
All you need.. don’t need scientific level accuracy
If they aren't smoking then they are fine. 😂
Yea, no need for a Vaisala.
+1 for NAPA calipers. Replaced all four on my 2007 4Runner over some years due to my factory units doing the same. They are quality remans, usually available next day and inexpensive.
I got this caliper replacement job done today. So far thermals look normal now.
I know you can do the electro bleed on the rears with another person on the brake pedal but just did a solo pressure bleed.
A little extra overhead of what job could have been but not a big deal.
Remember these? I was gifted one decades ago and the only use they get is as an assist for brake bleeds. I position it between the pad side of the brake pedal and against the seat bottom to simulate the second person. Takes some practice but has worked well for me.
I got one of these...after over 20 years of two-person bleeding....it's been a good investment. Mrs. Rednexus is certainly happy to not have to sit in the rig and push the pedal up and down upon my command.
Exact unit I use for all my cars now.
Are you using the included reservoir cap or something else? It's a bit of a pain to affix to the GX brake booster unit but is workable.
