I'm making brackets to use in conjunction with my 50mm slinky kit; but I'm thinking about moving the axle forward more than 11mm...
I read where
@Box Rocket wrote:
and seeing the relative fender heights of his 75mm slinky kit vs my stock truck, as mentioned here:
I laid out Adam's radius arm arc and tried to match the position of a 35 (which is what I'm going to run) as it compresses into the wheel opening so that I can take advantage of the firewall clearance he referenced above.
This puts me at 39mm forward on my 50mm drop bracket, or just over 1.5" forward - within the recommendation quoted below:
Here's where I am so far - my objectives are: self-locating (for easy alignment), reversible (maintains the stock hole if ever needed), and reinforce the factory mount (I ran a ramp up into the opening on the back of the factory bracket to give it strength for lateral impacts and am making the mount 3/16" thick.)
I'm not going to seriously crawl with the FZJ80, and I figure with 35" tires it will still be gaining 1" of ground clearance over the factory bracket and 33s... (and since it doesn't protrude below the arm itself, it shouldn't hang on any obstacle the arm might be sliding over..)
I realize the approach angle benefit, but I'm curious, however, what if any unexpected consequences there will be to moving the axle that far forward in terms of actual use? For instance; does the stock front driveshaft have enough plunge/extension to accommodate that at full droop? Potential binding of the front panhard? etc?
Thoughts?
