ats4x4dotcom said:Once the spring length is exceeded, regardless of the shock length or shocker being used, there is no more downforce other than gravity.
Did you get in to work late today? Where ya been?
ShottsUZJ100 said:Did you get in to work late today? Where ya been?
ats4x4dotcom said:Been dealing with salesman speak all morning, people trying to sell things as salesman, rather than on technical knowledge.
So after dealing with them, I thought I better log on here, while I was on a roll![]()
landtank said:I don't think you understood my explanation. Because the weight of the vehicle is on the inside of the tire that is being compressed some of that weight is transfered to the other tire. I'm sure you've seen pics where the low side spring is loose because of using long shocks, it's this force that is pushing down the axle on that side.
landtank said:I'm not saying the shock was doing it but rather explaining what Shotts was seeing and that it was more than gravity.
landtank said:I realise there are other facters in this like the amount of bind in the system.
I came upon this thread accidentally and saw Shotts taking some shots so I thought I'd try and help others understand what he was having trouble explaining.
ShottsUZJ100 said:The live axle acts as a lever as it rotates around the d-shaft and therfore more pressure is put on the drooping front wheel because of the pressure and weight on the stuffed wheel. IFS doesn't do that so you get less traction with IFS.
Now, on this thread, people discredit that live axle advantage you mention. They're all hung up on springs and shocks. I don't give a rats rear what made the improvement.![]()
ShottsUZJ100 said:Adding the N74L shocks helps this "problem" as the added rear pressure on the rear wheel when flexed helped to put added pressure on the opposing front. This helped F&R in the articulation dept.
sleeoffroad said:Run that by me again?What does the driveshaft have to do with the leverage point of a solid axle?
This thread was about the possibility of a shock pushing the axle down.
It was not about the merits of installing a longer shock.
It was not about your seat of the pants feeling.
It was purely about a comment you made in a post that I wanted to show was not correct so that people that read it will not get the wrong idea.
There is no reason to cloud this over.
Maybe I should have made the title a question, maybe I should just have said
" A REGULAR SHOCK CAN AND DOES NOT PUSH AN AXLE DOWN"
in response to
sleeoffroad said:No it is not sematics. I ask again, what does the driveshaft have to do with leverage?
sleeoffroad said:John, I did read it. The problem is that you make statements which are not correct. It is not a simple matter of semantics.
The axle does excert some leverage, but that happens around the link points. It has nothing to do with the driveshaft. So why is it wrong to point out that these statements are not correct.
Yes, I am picking on you. Why do you ask. You have your truck in a number of magazines, you have a site detailing mods etc, etc. So by default, newbies read these things and say, " Hey, look at what John has done with his truck, therefore what he says must be correct" however some statements you make are just not correct. Someone has to point this out.
If you have problems expressing what you are trying to say, consult with someone and then post. Don't just post statements about technical issues and think we are going to let them slide.
ShottsUZJ100 said:I said:
"I've had some great ideas for vehicle modifications and some have turned out with excellent results. For the technical reasons why they worked, ask someone else."
wngrog said:Ad that to your signature too and we will stop picking on you.......
