- Joined
- Jun 6, 2005
- Threads
- 74
- Messages
- 1,404
- Location
- Jacksonville Beach, Florida
- Website
- exitoffroad.com
We're finally ready to share all the options that are here or coming from Dobinsons Spring & Suspension for the new 250 Series Land Cruiser and Lexus GX550. I'll be posting up all the options and specs, as much as I can share, and also updating it as needed for when new parts or options are added.
If you're already running parts from Dobinsons, please post up photos of those and your rig to share with everyone else. We might ask for some measurements from you too.
We're looking at March/April 2025 for many of the parts to come in, including the new coils for the front and some for the rear, the standard travel front struts, strut mounts, and the UCA's. Some parts are shared among the Tundra/Sequoia/300 Series platform, so they're already here and in stock.
The LC250 specs are all based on the 2.4L and 2.7L gasoline engines. I won't be listing the non-USA engine coil spring options, to avoid confusion.
The GX550 is based on the bigger V6 engine and non-hybrid, so the rear lifts a little more without the extra weight that the LC250 hybrids have.
The main difference between the LC250 and GX550 options are the coils, everything else is the same. The GX has a heavier front engine, and a lighter rear end (no hybrid battery pack in the cargo area)
Complete Lift Kit Builder Pages
These pages show all possible options on one page for you to build a complete kit, with either the IMS or the MRA shocks.
Dobinsons 2-3″ IMS Lexus GX550 Lift Kit
Dobinsons 2-3″ MRA 3-Way Adjustable MRA Lexus GX550 Lift Kit
Read about the 3 different types of Dobinsons shocks
And all of the components are also sold separately. For the full details of each specific product, click on the link to go look at each product page. Will add shock specs/lengths on those pages too as I get that info
Front Struts
GS59-660 - Twin Tube Extended Travel, fixed coil seat height for 0-3" of lift. These include a droop spacer, which goes under the strut mount for lifts over 2", and then UCA's and a diff drop kit are required due to the extra travel
IMS59-60660 - 2.6" Body, Extended Travel, adjustable height monotube for 0-3" of lift. These include a droop spacer, which goes under the strut mount for lifts over 2", and then UCA's and a diff drop kit are required due to the extra travel
MRA59-A662 - 2.6" Body, Extended Travel, 3-way adjustable valving (high and low speed compression and rebound adjustments), height adjustable monotube for 0-3" of lift. These are extended travel and require a diff drop kit and UCA's at any lift height
Rear Shocks
GS59-441 - Twin Tube shocks for 0-3" of lift
IMS59-60441 - 2.6" body for 0.5-3" of lift, monotube shocks
MRA59-A441 - 2.6" body for 0.5-3" of lift, 3-way adjustable valving (high and low speed compression and rebound adjustments) monotube shocks
Front Coils for LC250 - Offered in Teal, Black and Red Colors
C59-882 - 2.0" lift with stock weight
C59-816 - 2.5" lift with stock weight, or 2.0" lift with 110-220LBS added front end weight (bumper, winch, skids, etc)
C59-818 - 3.0" lift with stock weight, or 2.5" lift with 110-220LBS constant added weight
Front Coils for GX550 - Offered in Teal, Black and Red Colors
C59-816 - 2.0" lift with stock weight, or 1.5" lift with 110-220LBS added front end weight (bumper, winch, skids, etc)
C59-820 - 2.5" lift with stock weight, or 2.5" lift with 110-220LBS constant added weight
Add preload with IMS or MRA struts to tune the lift height up as needed, like 1/2" lift via preload for 3" of total lift
Rear Coils for GX550 non-Hybrid - Offered in Teal, Black and Red Colors
C59-883V - 10mm (0.4") Lift, Variable Rate - less lift, but more load support when loaded or towing
C59-885V - 50mm (2.0") for GX550, Variable Rate with 0-110lbs rear end load
C59-817V - 50mm (2.0") for GX550, Variable Rate with 175-330LBS rear end constant load
C59-819V - 50mm (2.0") for GX550, Variable Rate with 550-770LBS rear end constant load
C59-821V - 50mm (2.0") for GX550, Variable Rate with 990-1200LBS rear end constant load
Rear Coils for Land Cruiser 250 Hybrid Models - Offered in Teal, Black and Red Colors
C59-883V - Stock height, stock weight, Variable Rate - no lift, but more load support when loaded or towing
C59-885V - 12mm (0.5") Lift, Variable Rate with stock weight rear end
C59-817V - 50mm (2.0") Lift, Variable Rate with 0-100LBS rear end constant load
C59-819V - 50mm (2.0") Lift, Variable Rate with 200-400LBS rear end constant load
C59-821V - 50mm (2.0") Lift, Variable Rate with 500-700LBS rear end constant load
C59-823V - 50mm (2.0") Lift, Variable Rate with 800-1000LBS rear end constant load
C59-825V - 50mm (2.0") Lift, Variable Rate with 1100-1300LBS rear end constant load
Front UCA's
UCA59-212K - Billet Aluminum, reuses OEM ball joints for a maintenance free life, OE-style high quality rubber bushings for maximum NVH dampening and longevity, No greasing or maintenance required at all, completely noise-free operation, Adjustable on-vehicle for quick and easy alignment, Adjustable Camber and Caster for perfecting the vehicle’s handling
Front Strut Mounts
SC59-021 - OE replacement strut mounts, allows you to order your front suspension completely assembled prior to shipping, and not needing to disassemble the original coilovers, and no special tools needed (safer). Includes new bushings and hardware
Diff Drop Kit
This needs to be run with the extended travel front struts, as CV bind will occur at full drop without it in place
DD59-542K - Diff drop Kit for Lexus GX550, 3rd Gen Tundra and Sequoia (won't fit LC250)
DD59-644K - Diff drop kit for Land Cruiser 250 and 2024+ Tacoma
Adjustable Rear Trailing Arms
These allow the rear pinion angle of the truck to be set properly once it has been lifted. They're also much beefier than stock
WA59-547K - Dobinsons Adjustable Rear Lower Control Arms with OEM style rubber bushings installed
WA59-747K - Dobinsons billet Adjustable rear lower control arms with OEM style rubber bushings installed
WA59-571K - Dobinsons Adjustable Rear Upper Trailing Arms with OEM style rubber bushings installed
Rear Panhard Rod (track bar)
This is recommend with a 2" lift or more. It allows you to re-center the rear axle under the frame
PR59-1421 - Adjustable length, new OE style rubber bushings already installed
Front Bump Stops
For those people who will be hitting it hard offroad, out in the desert, or wherever they may bottom out, a set of upgraded bump stops should be strongly considered
BS59-560 - Includes multiple height shims to set the bump stop gap accordingly and also prevent coil bind if preloading
Rear Bump Stops
HBS59-013FKK - Dobinsons Rear Adjustable Hydro Bump Stop Kit, includes coil isolator replacements with new bump stops, adjustable length, nitro charged
Rear Lean Correction Spacer
This can be used to correct a lean on one side, or add one to both sides to add 15mm more lift.
PS59-4035 - Rear 15mm Spacer made from polyurethane
Rear Sway Bar Links
SE59-591 - Adjustable length rear sway bar links for 1-4" of lift
Dobinsons GS (Twin Tube) Lift Kit | Land Cruiser 250 2024+
Dobinsons IMS Lift Kit | Land Cruiser 250 2024+
Dobinsons MRA 3-Way Adjustable Lift Kit | Land Cruiser 250 2024+
Dobinsons 2-2.5″ GS (Twin Tube) Lexus GX550 Lift KitDobinsons 2-3″ IMS Lexus GX550 Lift Kit
Front Struts
Rear Shocks
Front UCA's
Front Strut Mounts
Diff Drop Kit
Front Bump Stops
Rear Bump Stops
Rear Sway Bar Links
