DIY: Replacing heater hose pipe T's *important* (1 Viewer)
paflytyer
100s in the Hills
Media Partner
ColoRADo
Today I replaced my Pipe T's for the heater hoses. This should be included in your 90k service, but most shops (even Toyota) usually don't do it. If your service was done at Slee, they are one of the few that do it. That should tell you something.
It could leave you stranded and overheating somewhere far from home. For less than $15 in parts and about an hour, you can do it yourself. This is a 1 :banana: job for anyone with very basic tools. Long arms would sure help too. Toyota will charge you $100-$200+ to do it, so save yourself some time and a few bucks. Cheap insurance when you're far from home.
After some trepidation and fretting over replacing these with SS, brass or OE plastic, I decided that the OE ones lasted me 100k, I'll just replace with those. These Pipe Ts connect the hoses that carry coolant to your heater radiator. One side carries much hotter coolant than the other, so that side will likely fail long before the other. Just replace them both.
This job is a real PITA because you almost have to crawl into the engine bay to get at these things. Once you get there, you have to really bend and stretch to reach the clamps. Make sure you wear gym shorts or something without a belt otherwise you'll really dig into your fender. Remove the engine cover to get the best access.
They are located here:
[URL="http://i1216.photobucket.com/albums/dd364/coflytyer/mud9.jpg"] [/URL]
close up
[URL="http://i1216.photobucket.com/albums/dd364/coflytyer/mud10.jpg"] [/URL]
Part # 87248-60460
[URL="http://i1216.photobucket.com/albums/dd364/coflytyer/IMG_0892.jpg"] [/URL]
Tools you need:
Step stool
Pliers
A flathead might help in prying off the hoses
Blanket or something to drape over your fender to make it more comfortable
Soapy Water
I used a stepstool and a moving blanket draped over the fender/engine bay. It's still a long reach. (I'm only 5'9") I parked facing slightly downhill in my driveway to try and keep the coolant loss down to a minimum. I did have to move the stool a lot to get in the best position to unseat the hoses. You'll see what I mean when you do it. There's a reason why Uncle T charges so much. [URL="http://i1216.photobucket.com/albums/dd364/coflytyer/mud13.jpg"] [/URL]
There is a ground wire that's clamped to the heater hose. Just unclip that plastic clamp and set it aside. Now you can move that ground wire out of the way.
[URL="http://i1216.photobucket.com/albums/dd364/coflytyer/mud1.jpg"] [/URL]
The real PITA is getting at the clamps with your pliers. Other members suggested using oil or lubricating spray to make it easier to rotate the clamps to get at the nubs. I didn't want any oil left on there collecting dirt and grime, so I used a water bottle filled with soapy water and a tiny hole poked in the cap. Easy to spray a stream of water right on the clamps and help them slide.
The shorter the handles on your pliers, the easier it will be to get those clamps. The curved head of channel-locks makes it even easier. Spray some soapy water and have a go at those clamps. Just slide them back off the T's.
[URL="http://i1216.photobucket.com/albums/dd364/coflytyer/mud2.jpg"] [/URL]
I did one set of clamps at a time, but it's probably easier to do them all at once. Once you get the clamps off the T, carefully work the hoses off. This is where you'll likely break the T's if they're brittle. If you've got over 150k and they've never been changed, it might be worth clamping the hoses so you don't lose any pieces down into the lines. But I think that's unlikely too. If it does break, I would just remove the entire hose and fish them out that way. Although, you'll likely lose more coolant too. It may be worth it to drain a little out of the petcock at that point.
There's not a lot of room to clamp them anyway, and you're likely to break them just trying to do that. I say just go slow and careful and you wont need to clamp them. It takes a little work to get them off, so take your time and be patient. You'll be in an uncomfortable spot, so don't get frustrated and start yanking things around.
If you're parked slightly down hill, you'll get a small amount of coolant from the firewall side to run out when you pull the first hose. Maybe less than 1 cup worth. You could try to catch this in a clean cup and refill the radiator with it, but it's such a small amount, I just caught it with a towel.
Replace old ones with new Pipe T's, reconnect the hoses, squirt some soapy water and work those clamps back up onto the T's. You could turn those clamps to give them easier access the next time you do this. I just put them back in the same indentations they already made on the hose originally. 90K from now, when I change them again, I'll just replace the hoses and clamps too.
New ones
[URL="http://i1216.photobucket.com/albums/dd364/coflytyer/mud5.jpg"][URL="http://i1216.photobucket.com/albums/dd364/coflytyer/mud5.jpg"][URL="http://i1216.photobucket.com/albums/dd364/coflytyer/mud5.jpg"] [/URL][/URL][/URL]
Replace that plastic snap clamp on the ground wire and pick up your tools. At this point you could burp your coolant system, but I don't think it's necessary. The tiny amount of coolant you lose doing it like this is coming from the heater side. You never lost any coolant from the block. Although, I did it anyway. I turned the truck around so It was facing uphill, opened the radiator cap, started the truck, turned the heater on high, let the coolant circulate and added maybe 1/2 cup to top it off.
Last, check for leaks. Hopefully, you just saved some $$, gained some piece of mind and improved the longevity of your system.
Old ones
[URL="http://i1216.photobucket.com/albums/dd364/coflytyer/mud7.jpg"][URL="http://i1216.photobucket.com/albums/dd364/coflytyer/mud7.jpg"][URL="http://i1216.photobucket.com/albums/dd364/coflytyer/mud7.jpg"] [/URL][/URL][/URL]
One of my T's was in perfect condition, the other didn't break on me, but you can clearly see what the heat has done to it over the years. I *think* I had plenty of time left, I squeezed it pretty hard and it didn't break, but I'm glad I replaced it. YMMV. I'll keep the other in my truck as a spare.....just in case. Someone else might need it for a trail repair! Thanks to those members who answered my questions when I looked into doing this. This probably isn't on the top of everyones list, but with the high milage most of us have, plastic + heat + time = failure. I think it's pretty important.
Stan
This probably goes without saying but, I should also add....... Don't try this when your engine is hot. You'll get burned. Wait til you're completely cool.
If you lose any coolant onto the ground, make sure you clean it up well. The sweetness of it will lure your pets and it will poison them when they lick it up. If you don't have pets, your neighbors pets might come for a drink too.. If your neighbors don't have pets, Mother Nature requests you clean it up anyway.
paflytyer,
Thanks for bringing this to my attention. I need to replace those too. They will deffinitely be on my next parts order.
....And nice write-up, by the way!
  • Like
Reactions: KDL
If your vehicle is getting 8 years on then the hoses should be changed as well.
If you use a cable type hose clamp plier it shouldn't take but a few minutes. That type of plier seats onto the spring clamps from any angle and the cable is usually about a foot long so you can clamp/release however is convenient. Worth the money since everything uses spring clamps these days.
Search for 'hose clamp plier cable' online. Easy to find.
J
Yeah, those hose pliers work great. However, you'd need 3 pair to clamp all three hoses for this job. At $20 a pop, you'd be better off just paying someone else to do it.
I considered using 2 inch C clamps and some wood to make my own clamps, but I just dont think you need them.
Edit: After thinking about that for a few minutes, the hose clamp pliers could work with only 1 pair. Just clamp the hose in between the T and the firewall. It will prevent the cup or so of coolant from getting out. The other hoses will have just a tiny bit of cooland in them, just leave them upright and the coolant won't spill out. Just be careful if you use the hose clamp pliers, there isn't a lot of room to clamp and you may break off the end of the T.
^^^ Sorry, we were talking about 2 different tools. To avoid any confusion, both of these tools could make this job easier. But unless you've got other uses for them, they aren't needed to do this. Save your $$.
Cable Type Hose Clamp Pliers (for getting at hard to reach hose clamps)
http://www.amazon.com/dp/B000F5JM0O...&hvpone=&hvptwo=&hvqmt=&ref=asc_df_B000F5JM0O
Pinch off Pliers (for pinching rubber hoses)
http://www.sears.com/k-d-tools-kd-145-hose-pinch-off/p-SPM217372681P?prdNo=2&blockNo=2&blockType=G2
True; the cable type hose clamp pliers are not an every day item. I habitually collect tools as I repair things since the few times I have not done that I have regretted it :). For example I have the hose clamp pliers from use on another vehicle..figured i'd never use them again but here it is a few years on and I'll need them for the LX as it happens.
IMHO tools are always worth it.
Just curious, but does anyone know if there is a metal (brass or something) alternative that may be more durable? Just a thought
Problem is chemical reaction. IIRC somebody posted about this issue. Can't remember who.
Thats why you get the stainless steel kind.....but they are $$
They were using brass from HD IIRC. I think it was Dan who was talking about how the brass reacting with the fluids. Anyways, I can do a test on the fluids now, and install brass and have it sent off or tested somehow.
Btw- SS lines are cheap when you loose all your fluids in death valley.
  • Like
Reactions: KDL
It was me, and while galvanic corrosion is a real possibility it would be unlikely for anyone here to have an issue IMO because we do proper maintenance and run quality coolant. If you were way out and ended up loosing the coolant and replacing with ground water for a few days you might have a problem.
I decided I was over complicating things (as is my nature) and just replaced plastic with plastic and carry the non-crubly take off as a spare. The factory parts are well designed with respect to flow and should not produce restriction or cavitation, substitutes may or may not be as well designed from a flow standpoint.
Just replaced mine with brass.
Note: it's a lot easier to replace these buggers if you do a body lift as the engine and all is lower and allows easier access to those hoeses. Albeit, it still doesn't help the fact that they are in the middle of the bloody firewall and one will still have to reach!
I also replace my hose clamps with the old school stainless steel screw strap type.
100TD makes a good point. Change the hoses... and if you cut the hoses, you won't have to deal with the position of the OE clamp on the T-fitting nor bits and pieces of plastic breaking off into the hose.
You said old school so I'm guessing you went with the worm drive clamp and not the constant torque type? If so, you might want to consider the later type for this application. The hose will eventually shrink and get compressed. The constant torque clamp will accommodate that.
Edited for part numbers:
(I take no responsibility:flipoff2:)
(98-02) Complete hoses, Tees and clamps
• (2) Heater T’s (87248-60460)
• (1) Heater hose (87245-6A190)
• (1) Heater hose (87245-6A180)
• (1) Heater hose (87245-6A220)
• (1) Heater hose (87245-6A210)
• (1) Heater hose (170mm)(99556-20200)
• (1) Heater hose (87245-6A201)
• (8) Hose Clamps (96134-42100) (Horizontal hoses off Tee)
• (4) Hose Clamps (90467-19022) (Vertical hoses off Tee)
(03-07) Complete hoses, Tees and clamps
• (1) Heater hose (155mm) (99556-20155)
• (1) Heater hose (87245-6A800)
(RED highlights the difference between the two lists.)
Correct, the worm drive type is what I used. Not sure which clamp you're referring to. Which post in this thread was it in?
One more note on changing the Tee's if you are doing a body lift: It would be a good idea to lengthen the two hoses coming from the fire wall. I'm only talking about an inch longer.
I personally need to go back and do that myself so I don't stress those hoses.
BTW thanks Hoser:cheers:
