looks available to me....
Could not find the hose part numbers for T to heater core. There are two and can anybody post it here please?
I did one set with metal as it was special case. I've done dozens with OEM plastic and prefer those. I then recommend replacement as PM every 7 t 10 year, aligning with Timing belt job or coolant flushes. Replacing thermostat and radiator cap isn't a bad idea either at the 7 to 10 year.I’m ordering tomorrow! Metal or plastic! I’ve read through the threads and still confused..... I truly want the best without any problems. Post a link to the best part y’all think! Thanks
Either is fine. The OEM plastics are known to last a long time with the caveat of sudden failure after X number of years/miles. The metal tees don't have much historical data but could potentially last the life of the car. I'd decide based on whichever is cheapest/ available quickly/ gives me the warmest fuzzies.I’m ordering tomorrow! Metal or plastic! I’ve read through the threads and still confused..... I truly want the best without any problems. Post a link to the best part y’all think! Thanks
The other ends of the heater hoses are attached to barbed metal fittings straight from the factory. Those ends never seen to be the problem, so that should allay your fears. The trick to both heat cycling and tees that are slightly off, dimension-wise, is to use constant tension worn clamps like the Breeze #10 constant torque clamps, which have been recommended throughout the thread.In other forums for other vehicles, there is a fear of putting a hose clamp over barbed metal fittings. The thought is that over time, with heat cycling, the clamp will cut into the hose. This could make it loose, or fail outright under pressure. This is discussed primarily for fuel hose, where leaks can be dangerous, but the pressures are higher there too.
All I'm saying is that there may be pros and cons to either metal or plastic.
Good luck,
Dave
PS I used plastic OEM
