I decided that the stock headlamps, high and low beam, really are just horrible so I researched several different options and decided to try the Diode Dynamics. So, my first attempt at installing, removed the battery, removed the old bulbs and tried to insert the new ones--no go on the install because of the o-ring was obstructing the bulb from properly seating. Removed that, got the bulbs in, all four, and...nothing. So I pulled the bulbs, ran a direct lead from the battery posts to the +/- leads from the new bulbs and they had power. So the bulbs are functioning but once I plug them into the wiring harness, nothing. I installed the old bulbs and the powered right up.
I will next attempt to see if I am actually getting 12 volts going to the headlamps. I hear that sometimes the actual voltage going to the incandescent bulbs doesn't need 12 volts and could actually function at lower voltages whereas the LED needs 12.
Would love to get some feedback from anyone that has gone through this process or at least is smarter than I am.
Thank you in advance.
