diff. questions
Discussion in '60-Series Wagons' started by 83cruiser, Aug 1, 2005.
  1. 83cruiser
    83cruiser
    6
    Jun 27, 2005
    Hi, i heard a rumor that the electronic locking diff from a tacoma can be used for the rear diff on a 60. Is this true and if it is, is it worth the trouble of doing the swap or just go w/ a aftermarket diff? money is tight that is why i'm looking into this. Also my 83 60 has a 2" lift can i fit 33"s w/ out rubbing too bad. Also will they make the truck a PITA to drive on the highway? I'm new to 4x4's so please bear w/ me. thanks ROB
    83 fj60 2" lift (i think)
    87 bmw 325is (anti-rice weapon)
  2. sl33py
    sl33py
    2,160
    8
    Jan 8, 2004
    Emerald City
    i am definately NOT all knowing, but from what i have gathered - w/ 2" you shouldn't have problems fitting 33"s. Some have them w/ stock (but keep it skinny 9.5ish). With your lift, i bet you could fit them no problem. Shouldn't be a problem on the road if your brakes are in good shape/adjusted. Someone else will chime in with more info i am sure.
    Sorry - no clue about the diff.
    Good luck!
    rob
  3. Doc
    Doc
    5,925
    Media:
    33
    Albums:
    1
    430
    Apr 26, 2004
    Utah
    33's wll fit fine with your lift. Highway driving will be easier with bigger tires.
    No idea on the locker, but still it can't be cheaper than an aussie locker. Do a search for Aussie locker and you'll find out what I"m talking about.
  4. stinkyfj60
    stinkyfj60
    1,344
    3,411
    Apr 22, 2004
    Roodepoort, South Africa
    I am clearing 33X12.50s with a one inch body lift and about 1 or 1.5in shackle lift. Its close though! But I bet you would be fine.
    I dont think the Taco locker will fit, I could be wrong but I thought the Taco is the smaller diff, similiar to the front of a FZJ80
  5. cruiseroutfit
    cruiseroutfit Supporting Vendor Moderator
    8,832
    6,598
    Jan 9, 2003
    Utah
    Taco locker is an 8", you need a 9.5" E-locker out of the rear of a FZJ80 :D
    But, if you find a cheap 8" E-locker, send it my way :D
