This is what you're looking for....
https://www.amazon.com/ARB-170112-D...sr=1-1&keywords=arb+differential+breather+kit
I have this kit installed on my 100 Series. Actually, 2 of these kits. I ran the rear diff breather up behind the left taillight so I would be able to maintain a consistent "rise" in the line. The front diff and transfer case breathers run up to the 2nd kit which is installed on the firewall.
Any pictures of where you mounted the filter under the hood. Did you have to drill anywhere to get behind the taillightThis is what you're looking for....
It says it doesn’t fit a 100 series. Is that true or will it fit my 06?
The ARB units are nice looking, but you can extend your breathers for a lot less money and effort going the DIY route, no drilling of any holes required, and you get better performance, IMO.
I have no doubt the ARB is quality. I wish the kit came with clear hose and three separate filters, though.Yup! Had I done more research, I would have gone the DIY route outlined in the thread above. But, I got antsy and went the more expensive ARB route![]()
Yeah, the clear hose makes it easy to see if there's any fluid trapped in the hose. The other issue is that the hose needs to be as vertical as possible along its entire length to make sure that fluid doesn't get trapped in a horizontal section. If you have to route all of your breathers to the firewall, you could be in trouble. Hence, my desire for three separate filters.Hadn't considered clear hose. But, that would actually be a really good idea. Would make it easier to spot any blockages for sure.
Hey guys, can you not just use 8mm nylon air line up onto the engine bay, then use pneumatic exhaust filters on a bracket?
