G'day your post and the replies makes interesting.I think you need to get back to basics.What is your fuel pressure? Does it run rough/misfire/smoke. new air cleaner fitted? How did you run in the rebuilt motor it's very important to get some light/medium load on a motor after a rebuild,If I dyno a motor i have just rebuilt it some load 5 mins after startup or the new rings can glaze very quickly
I would also like to add that a rebuilt diesel can be tight I have experienced a few that felt very flat in the top end for the first 5000km or so. DONT WORRY ABOUT ABOUT TIMING ETC If you don't have a diesel timed right you will know it staight away! it won't run and if it does start you will probably wish it hadn't
My advice; Check the basics if their OK just run it in for 5000km and if it's no better then delve deeper
