For Sale DFW: 1997 Toyota Land Cruiser
Status
Not open for further replies.
Year
1997
  1. 80 Series
Texas United States
Mileage
310000
Color
green
Outside Link
https://www.facebook.com/marketplace/item/2517602198415719
Decently built rig ready to go. Build thread here. It does not have F+R lockers, there is a switch installed to control after market e-lockers when the time comes (i can even reinstall the relays to make the dash lights light up if desired)
$15k o.b.o.
It's not a perfect rig, it does have a few bumps and bruises but cleans up really well, and most importantly has no rust.
Now on to the good stuff. It's a 1997 the pictures make it look black but it's dark green. I believe I am the 3rd owner and have put the last 30,000 miles on it. (I purchased it from a Mud member) I have completed the Continental Divide Trail with it, and all the the trails in the San Juan's. I don't hesitate to drive it anywhere, and it's my daily. The tent, fridge, enclosure, trasharoo, tracks, accessories on the outside of the rig are not included in the price, but can be for the right price
Recent Maintenance Items:
@286,194 miles I replaced everything from the valve cover gasket up, Spark plugs, spark plug grommets, plug wires, cap, rotor, Throttle body gasket, fuel filter, belts, pcv valve and hoses, starter rebuild, heater control valve, injectors
287,584 Miles - a/c idler290,800 miles- Air Filter, Radiator cap, TRE's
291,102 - Coolant flush, thermostat, oil pressure sending unit
295,000- 5 new tires Trail Grappler M/t 315/75 R16, rebuilt birfs
296,041- PHH Bypass/replacement, upgraded brake master cylinder installed, fuel vapor canister, brake flush, alignment, all diff fluid changed
302,391- Blue Fan Clutch Installed
New power steering pump
Mods:
Suspension:
Installed at 296,041 miles:
Icon Heavy Springs/ShocksDelta 3L+ Drop radius arms and bushings
King Steering Dampner
Slee extended brake lines
SS brake lines
Delta Rear Panhard bracket
Delta Front Sway Bar Drop Brackets
Exterior:
Bowfin rack
Safari Snorkel
Custom built rear swing out for full size spare
Warn VR 12k winch mounted on Trail Tailors hidden winch mount
Factor 55 Ultra Hook
CoLight 50 inch light bar, ditch lights, and rear lights
5% tint on all rear windows and 20% on the front
Interior:
Brand New Carpet installed 5/25/20231 layer of sound proofing 1 layer of foam
Brand New Steering Wheel Leather Wrap Replaced 4/24/2023
Dash is perfect no cracks
Switch Pro installed on Wits End mount
Sony Double Din and new infinity speakers in the 4 passenger doors
Homemade Slide Out Drawers with front runner table fitted in
Midland Radio
Wiring for Fridge with usb and 12v plugs
Other Mods:
ARB dual Compressor under hood and Dual Battery Setup with Odyssey AGM34 battery and Blue Sea automatic disconnect mounted using Slee mounts
Items the need addressing:
Still has the factory gearing, they work and it runs 75-80 down the highway, but as everyone knows it takes a minute to get up to speed
Shade for the sunroof has the handle missing, needs replaced
Windshield is cracked hasn't really bothered me and just passed inspection
Naturally the front seats need to be recovered
Minor cosmetics like small areas of clear coat missing on the right rear quarter panel, small dents and dings but nothing major.
If you've read all this and are interested and have more questions feel free to message me.
Status
