destins 1964 fj40 FST restore thread (1 Viewer)
I will probably clean up the frame a bit when the tub is off.
Not a lot of rust on the frame :D
Probably degrease, rust neutralize and paint the bits that need it.
Then maybe spray that light grease stuff I have been reading about on it.
No real need to blast and repaint the frame, it looks great :)
:eek: You're crazy.. when's the next time the tub will be off the frame? Might as well do it now while you can.
The only way I would spray parts on like that is if I had already painted the back/hidden side/section...and even then I probably would not do it this way. I prefer to take it all apart, and make sure she is clean, and properly painted...even when I airbrush smaller things.
Just the way I'd do it if I was taking the time to be this thorough...what's an extra couple of days at this point :beer:
While I wouldn't call you crazy, I agree with Wes...you are so close, might as well do the frame now...I wouldn't por 15...just a good primer sealer paint. :meh:
Remove everything, paint the edges, backsides, interiors, nooks, crannies. Then bolt the pieces back in place and overcoat the whole thing. remember these are all either moving pieces or have huge gaps where you can see the "hidden" surfaces. Nothing worse than folding down the windshield and have the bottom edges staring you in the face with poor or no finish. :bang:
Oh yeah, and paint the frame. :hillbilly:
:D
Right on, all good points ;)
Wasn't paying attention. Your frame is too nice to ruin with POR15. Clean, , use an etching solution to kill the rust, neutralize, prime and paint.
por 15 is not so great eh?
( sorry just noticed you mentioned that too Dean )
I definitely plan on cleaning and hitting with metal ready or a similar etching solution. Priming and paint would be easy enough i guess hehe.
Hopefully i can get the tub ready for removal by next week, we will see :)
Destin I had my 65 painted at the panel shop in a full paint booth. I know and trust these guys - they had no hesitation to pull everything off including the windscreen, hinges - the lot and paint them separately. I very much left it to them to apply their expertise. In a cruiser that was reatively rust free have a look at the corner where the widscreen hinge should be in this early shot of it being stripped back.
Cheers Dobster
attachment.php
Cheers Dobster
Good point!
That settles it off it comes :D
Any tricks to freeing up those screws?
I have been soaking the lower screws of the hinge from the inner fire wall with penetrating oil. ( spray, tap and let sit )
However where the hinge connects to the windscreen, the rear of the hinge screws are not very accessible...
I guess i need to be just more patient like every one keeps mentioning :D
Thanks again guys :D
Cheers Dobster
impact driver and or heat
hehe
Those bolts have alot of penetrating il on em, would hate to see what heat would do hehe ;)
Do you usually us a torch?
I will likely let em sit for a while longer before i use more drastic measures, but it is good to know :)
Drastic would be drilling them out. If you can't get them out now you're going to need an impact driver. Use the correct size screwdriver or bit too.
btw do you have a link to more photos of that 65 FST?
:D
Advise is the same as above for the screws, lubricant - heat - impact.
There are a few photos in my album
https://forum.ih8mud.com/members/dobster-albums-1965-fj40-under-restor.html
But I have been mpressed following yours thread and will start up a thread once I can get all the pics together. It has been going on for a couple of years. My 25 arrived yesterday - Very excited :Dand will post more pics of it soon too.
Cheers Dobster
Cheers Dobster
nice man :)
And thanks :D
Love that green btw, looking good!
Post pics of your 25 when you get a chance :)
Did you make a little mount to hold your clutch and brake masters while it was being painted?
I was thinking about using a piece of metal to bolt them too and hook it to the engine while the tub is off ( so i do not have to rebleed the brakes etc again, just redid them :)
I don't think so. We new it was going to be a long process when we started, so I'm pretty sure that anything with any fluid was drained, so the brakes will definitely be re bled. As you can see from the pics they left the tub on the chasis to paint it, and I think the motor stayed on the chasis also. All the panels were taken off and painted first.
Cheers Dobster
