I'm going to jump in here as another data point since I too have installed 80 springs. I don't have answers, but the numbers you are getting in TS are definitely odd and not what I experienced at all. I don't have exact numbers, but when I tested after spring install and after rear hitch/bumper skin removal, I was getting readings in the high 3s. After 4x4 labs bumper install the reading crept into the low 4s. After a bit of sensor lift(not much since I was actually a little low in the rear to begin) I settled on a rear pressure of near 5. Set the front to the low pressure side of normal also and overall I think it rides pretty decent now. Nearing 200K miles on original globes so probably not perfect, but as good as it did before I started adding weight. Comfort mode can be a bit "floaty" depending on speed. Sport mode tightens things up to bordering on harsh. I usually stay in the middle two settings, again depending on speed and road quality.
However, ignoring the techstream numbers, your experience of harsh ride(if that's what bouncy means to you) without enough extra weight is spot on to what I would expect. I only took one drive without weight on mine and it was pretty harsh. Friend put non AHC 100 springs on his and it was too much to deal with even after sensor lift.
So, again, don't have an answer to why you're seeing the numbers your seeing, but can offer encouragement that the 80 springs can work in the correct scenario. I will get some current numbers from mine soon and report back to the thread also for comparison...
