Don't rule out throttle body just yet. It was the 2000, that had the most reports of issue with TB. You'll heard a sound as IG key turn to just ON, at throttle body. If you notice a delay in sound, that coincides with length of time IG keys needs to be ON before no symptom start. It'd be a clue.
Fuel Injector's to intake manifold grommet, would not be affected by KEY ON 3 sec:
The seal at bottom of FI's, are grommets in the intake manifold. Where they can leak air past them, it's not common with factory installed. But they are rubber, as such, shrink and harden with age. But if they are leaking air into intake ports of head, this would be a vacuumed leak. By spraying gasses like propane, gas from plumber touch etc.. RPM will increase as gas gets into area of vacuum leak. But a vacuum leak would not change, from just turning IG key to ON for a few sec. So this is not likely your issue.
If you do replace FI grommets. Make very sure, no dust/sand gets into port. Best time to replace FI grommets and seals, is when intake manifold off. Like during a starter job. Also in the 98-05 replace the O-ring & grommet at top of FI, in fuel rail. While FI's out, consider having cleaned, rebuilt & tested.
A word on misfires read through Tech Stream (TS (Technical Stream of data, from vehicle systems)):
I had this glitch fool me on one 4.7L, at first. As misfire spotted in TS, would go away in a blink of the eye. Engine had at times, of rough start and driver felt something was off at idle. She had been driving it since mile one now over 350K miles, so knew her engine "feel". What I found, fix the issue. Was replacing (with Denso coil) the only coil ,that had been replace previously. Which replacement coil, was not Toyota Denso or Denso.
Glitch in TS when watching misfires:
Fuel line & rail pressure, with IG key on:
I do not think fuel pumps fire up, until engine turning. But, I'm still learning ever day about systems in the 100 series, almost as much as I've forgotten:
It's been suggest, as I noted above! Which currently, "I am in doubt of". "Fuel pump fires up for ~3 seconds to build pressure in fuel rail, by just turning IG key to ON". I'm in doubt, because: If this the case where fuel pump did fire up. We'd not get long crank to start, due to excessive Fuel Injector leak down. Which is a condition we see.
I can think of two easy test I could do (with a proper functioning starting & fuel circuit). To test if fuel pump fires up even for just a moment when IG SW just turned to key ON, without engine cranking:.
1st) Disconnecting fuel line down stream off fuel filter, Easy, since no tools needed. Attach a hose to fuel filter and run to catch can. Turn IG key to just ON. if fuel pump does fire up, fuel would pump into catch can. Best time to do this, to reduce fuel spillage or spraying. Is after vehicle has sat and engine cold. As fuel pressure in lines drops with passage of time.
2nd) I do with my pressure gauge setup. Which I tie in between fuel filter and fuel line to engine. Once hooked up, I'd only need to turn IG key ON. Than read the gauge!
Key on 3 seconds or more:
I do have one 100 series that comes to me for service. That needs IG key turn to ON 3 seconds or more, or it just cranks without starting. It had a very bad battery short, due to battery tie down missing. Apparently a shop fix damage caused. One thing, they installing aftermarket immobilizer system. Seems electronics need, time to activate throughout system.
