BajaCruiser94
OK, so I did my homework and studied most of the relevant posts for air bagged rear suspensions; still the final answer is somehow blurry; do the air bags limit suspension travel while flexing off road? Responses normally are biased and/or not clear.
Here’s the deal, I have the 2.5” TJM suspension with gold shocks, front 25mm spacers and 305’s all around; I know the springs are progressive rate; no armor nor custom bumpers (yet!)
Problem is, when loaded with people and gear the sag is noticeable; and most of the trails I travel down here in Baja make the rear hitch dig deep into the ground causing chills on all passengers.
Anyway, here’s my plan up for discussion and/or destruction.
Elements in mind: AirLift/TJM or Firestone airbags + PUMA Compressor +2 solenoids + current un-used antenna up/down switch
- Normal Air Bag installation, inside springs, cutting bump stops.
- First solenoid used for inflating/deflating both bags, air input coming from compressor manifold
- Second solenoid to toggle between “T” setup and isolated bag setup (more details below)
- Antenna Up/Down Switch wired to the first solenoid for inflation and deflation
- Small toggle switch for “T” setup and isolated bags
Reading in past posts, there’s a lot of debate on “T” setups and isolating bags; both have pro’s and con’s depending on the situation.
T Setups in my understanding can work off road, one wheel flexes up, air is transferred to the opposite side; and there’s no significant added restriction to the normal articulation.
Isolated Bags, on the other side, can work on road and on higher speeds, where sway caused by weight and handling can benefit from stiffer bags when air is restricted inside each one.
Once again, this based on my understanding, maybe I’m wrong, maybe not?
On my proposed setup, a normal solenoid will be used to inflate and deflate both bags, and when isolated bag setup is desired, the second solenoid will just cut one bag from the system; of course, inflating and deflating will have to be with the T setup always; I’ll figure out how to do this with some wiring and relays; at least I hope so.
Before I start investing additional time, money and a lot of sweat (115F Weather) I wanted to run it thru my masters in IH8MUD; is this feasible and worth it?
Thanks.
-Emerson
Thanks.
-Emerson
