Coming soon- Write up - 5 speed conversion H151F (1 Viewer)
Ok, so I know that this is probably jumping the gun here and it will probably be included in your write up, however... Someone asked about the cost to have the work performed in Japan, how much would just the parts required for the swap be worth there? Have you added them all up yet?
All new parts from Toyota around $6k.
Used parts who knows; it is different for everybody depending on availability and cost of used parts?
Australia has many parts available; they are a bit pricey. I ended up buying many new parts.
My conversion was under $2k. But I had an extra A442F that I sold to help offset the cost
LandCrusher80
Yes it does.
Did we ever see the finished write-ups? Especially with the parts list?
It's all done in a word document, Will just have to posted one of these days, :rolleyes:
LandCrusher80
Also thinking of doing a H150 swap, the write up would really help :)
When truck is in neutral and the clutch is not depressed there is a rattling sound. Is this normal? Noise disappears when clutch is depressed.
(New OEM flywheel, new Exedy clutch & pressure plate, new OEM throughout & input shaft bearing )
Do you know which exedy clutch you went with? A part number would be a huge help!
