Coming soon- Write up - 5 speed conversion H151F
1HD-T + H150 + 4.10 + 315 will give you nice overall performance and top speed ..
1HD-T + H150F + 4.10 + 315 = my set up.
What is your speed at 2000 rpm?
LandCrusher80
H151F :cheers:
LandCrusher80
By my speedo correction it should be close to 100km/h ( likely bit less ) but I will grab my GPS to see how that goes ..
Update.
Just a bit behind schedule. All the welding is done. Need mount the tranny tunnel plate and then the MT will go in.
Hopefully without a hitch.
LandCrusher80
1HDFT + H151F + 4.1 + 315MT = mine also
definatly not for top speed wish I had 6th gear
What is the top speed? At 2000rpm what is your speed?
LandCrusher80
What would it run to pay for someone to do this, parts/labor?
I don't' know about your part of the world; but here in Japan the cost is
Yen 712,000 gasser / Yen 751,700 diesel.
LandCrusher80
The H151F is bolted up. Look the shifter holes line up :D
And a new rear bracket mounted for the console.
:beer:
All I got left is to figure out the neutral safety switch.
And I need a new shifter knob.
LandCrusher80
thick cable ( #10 IIRC ) one black and one white ( solid colors ) are the only 2 thick cables around the harness that goes to the tranny ...
Join both and you are done with the safety switch ..
LandCrusher80
Ouch, that is $8,764.89 USD at todays' rate for the "cheaper" petrol version!
:cheers:
Steve
Muchas gracias David!!!!!!!
All done!
Time to celebrate
:beer::beer::beer::beer::beer::beer:
Working on the write up.
Video will be later.
Good info David!
You might also want to consider wiring a switch in to the NSS instead of just a jumper if you have cruise control. It would also be a good kill switch for theft deterrence.
How does it affect the cruise control? A kill switch great idea!
