For instance, this morning I got in the truck, pulled choke, pumped pedal 7 times, gave it a good 15 seconds before I tried to turn her over. Nothing, repeated the process, Nothing. Repeat again, and she tires to fire over but nothing. This time 3 pumps of the pedal, wait only a couple seconds and turn and she will finally turn over and fire up though even with choke pulled idle is MAYBE 1k rpm. When the temp is above about 25* this is not really a problem or will take significantly less pumps/tries.
. However, What do I need to grease, lube or whatever to get it so that the cold does not affect at least the latching mechanism as badly?
