My virgin ears guys!!!!!(language please, family forum and all that...)
Go to chat if you wanna cuss
Montana Cruiser said:One last thing, where the heck is the "degree" symbol/key on a standard keyboard?![]()
Arya Ebrahimi said:My virgin ears guys!!!!!(language please, family forum and all that...)
Go to chat if you wanna cuss![]()
shocker said:If yer running on a Windows system, hold down the 'Alt' key and type 0176 on the number pad.
You can see how to do all the symbols if you go to START->ACCESSORIES->SYSTEM TOOLS->CHARACTER MAP on your computer.
/off topic
Kaderabek said:Doesn't seem to be any constant power back there in the rear quarter. I tapped into the hot off the trailer wiring, only works when the brakes are on. Tapped into the red wire on the main spool coming from the front, nothing, didn't bother to see if it worked with the brakes on.
I can see all the wiring under the driver's seat but can't tell where to splice in.
Guess I'll pull the center console when I get some time and go that route.
TJK
NorCalDoug said:All this poking around and looking for wires...you could've wired up a dedicated 12v outlet back there already![]()
Beowulf said:Todd,
I don't have my electronic version of the EWD here at work but there has to be a +12v back at the trailer harness since the brake lights work with the ignition off. Typical Toyota wiring switches the ground to complete the circuit.
-B-
Montana Cruiser said:TJK - I'm sure you are already aware of this, but I THINK if you are checking those wires AFTER the black box for the trailer wiring you wouldnt be able to find the hot lead, but you need to check the wires BEFORE they get there. Checking after would yield power with the brakes applied. As stated before, I am a wiring moron so if this is beyond basic flame away, I can take it. Just trying to help. My Toyota black-box trailering harness went bad and I spent the better part of 3 hours messing with it and wiring in a Hoppy brand one from Fleet Farm to fix it.
(#4...)Once I had all the goods (wire, small fuse block, 2 12V outlets), the entire job took about 45 minutes.Kaderabek said:I only have about 30 minutes invested so far.
By dedicated you mean run the hot wire up to the battery? It's an option but I hate the firewall.
TJK
woody said:just had mine apart to install a constant-hot 3-plug cig dealio....no constant hot wires under there...there is a HD switched one (3 wires in it) under the center console that I shoulda piped into for the CB, but was too lazy...ended up grounding the cig with the other grounds under there and running a constant hot to a fuse off the primary block (fused inline as well)
1996, BTW....(#4...)
