Can you guys tell me if this is normal when I tried to rock the tires back and forth. Thanks
Yup.
Yep, but looks on the excessive slop side of normal.
Pop the dust caps off the end of the hubs and the c-clip off the end of the birfs and look at how much slop there is at the birf/drive flange spline
It took me a while to get use to the clunk/thud of dropping my honda motorcycle into gear. Felt like the tranny was breaking every time.
Mechanic told me it's the "honda thud of quality".
How to fix this? Just rebuilt the knuckle and replaced the axles with RCV
Have owned this truck for 5 years. Don't remember hearing these noises
You need to check the drive flanges, see if they are worn. A tiny bit of wear leads to a lot of slop in the assembly.
It could also be in the diff, too much play between the pinion and ring gear due to wear or loose bearings.
It could conceivably be that your new axle splines don't meet the stock tolerances.
Or it may be normal and you just never noticed it.
Did you fit new drive flanges? New birf into chopped out drive flange could be a problem.
Some of it will be slop within the diff too, it's normal to have some slop because there's a lot of gear, to gear connections, and splined connections, all of which have some play.
The drive flange is the joint that has most leverage on it IMO.
it's the first thing I'd be looking at, and possibly the easiest and cheapest fix
Could be diff too. Moved up to 5.29 and it is noisy under load.
That right there would make me a little nervous. Mine are not noticeable.
So, are you running on 37s too?
If wear at the flanges gives a few extra degrees of play, with 18 inches or so of leverage in the tire diameter, a few degrees slop at the flange adds up to a few inches rotation at the tire circumference.
But sounds like your flanges would still have all the factory machining marks in them still.
If your driveshaft splines are dry can cause a clunk. This type of thing will often happen with the rig stopped, by shifting D to R, makes finding it easier using a stethoscope.
Doesn't look bad, but, where are the snap-rings? Also they look dry, should be greased.
The splines on birf end/drive plate should be greased.
I had a clunk that ended up being two different noises. Had to remove one before I could here the other. The first clunk was my rear driveshaft in bad need of grease. Caused when going into D/R and on the trail. Once gone there was a deeper thump. Felt like there was weird movement in my drivetrain on acceleration and sometimes at braking. Ended up being my rear control arm bushings. Rubber was shot. New bushings fixed that. Worth a look.
