Not sure about school, but I'll settle for some entertainment---
Some vacuum systems on the 2F use small continuous vacuum bleed lines in the routing to allow the release of vacuum when the state of that system changes (on/off).
These designed vacuum bleeds are small, and should be there, but they all add up.
1. Choke Opener-
That little mysterious white plastic doo dad inserted in the middle vacuum hose leading up to the air cleaner breather pipe is a bleed off orifice (doo hickey might be a better word) for the vacuum supply to the CO. You can see it in the schematic of the CO circled in red. It's a tiny leak, but continuous. Its purpose is to assure that the CO doesn't get stuck open, preventing the choke from working if some sort of weird obstruction occurred in the vacuum line going to the CO after it was actuated. If that unlikely event happened, the choke would be inoperable and a person could conceivably not be able to start the engine on a cold morning. They would be stuck up in the mountains, unable to leave & would eventually starve to death after they ate each other after drawing straws.
So that little plastic doo hickey with its tiny vacuum leak could save someone's life.
On to the next one:
2. HIC Valve.
On a stock 2F with all emissions equipment installed & working properly, the HIC valve is always in a state of movement on a non hot day, (below 92°F) constantly opening & partially closing, modulating between states of too hot & too cool, trying to keep the air temperature going into the air cleaner housing at a comfy 81°-91° temperature. This valve controls both the hot idle compensation by allowing some extra air into the manifold (vac leak) at hot idle -and- the HAI (hot air intake) flapper valve located on the air cleaner neck.
The air getting sucked past the exhaust manifold is mighty hot going up through the HAI valve so once the HIC valve gets some of that blazing heat, it closes back down, which then released the HAI flapper valve. This all happens kinda in slow motion since the HAI valve is slow to change to temperature.
The only way the HIC valve can close the HAI flapper is to be able to bleed off vacuum to it. And so it does. There's a small designed vac bleed off going through that valve while the engine is running. Without the vac bleed, the HAI flapper would get pulled and then stay open as long as the engine was running. The engine would probably overheat & blow a head gasket & leave the passengers of the car stranded in the wilderness where they would runout of food & eat each other after drawing straws.
Familiar drawings to us, posted here for others to refer to.
On to the last one
3. HAC System
This system too uses a continuous vacuum bleed off to release the outer vacuum actuator on the distributor. A little air (vacuum) is constantly being pulled through the bottom port of the HAC valve at any altitude. At low altitude it's a small designed parasitic vacuum leak going straight into the intake manifold, at altitude, a lot more air gets sucked up through the bottom of the valve into the carb to lean out the mixture. It's a vacuum leak too. Just an intended one for altitude.
The schematic in the FSM doesn't show this, but the testing section in the emissions FSM reveals it. If you check an old filter in the bottom of the HAC valve, you'll see that it's pretty dirty even if you never go to altitude. That's because a bit of air (vacuum) is always flowing through it.
If this designed continuous small vacuum bleed wasn't present in the HAC system, the HAC vacuum advancer on the dissy would get pulled at 4000 feet and wouldn't let go until the engine was shut off.
This could lead to the death of the passengers in the car...
Because....
When the passengers in the car drove down from the mountains from their glorious thanksgiving holiday with family & friends, the HAC vacuum advancer wouldn't disengage as they descended into Death Valley. The engine spark advance would be much too far advanced (6°) for that elevation below sea level and the engine would detonate severely. But since they had the radio turned up so high, they couldn't hear the pinging and the engine then would overheat and blow a head gasket... leaving them out in the wilderness in the middle of Death Valley with no food or water or cell phones. So once again, after a few days, these poor people would run out of food & eat each other after drawing straws.
But this time - they tasted like turkey!
Here's some minutiae I drummed up from my retired screen name.
High Altitude Comp (HAC) Valve
1987 FJ60 High Altitude Compensator (HAC) Routing
