2001LC
So do you think change the vacuum lines is all that was needed?
In my case, based on the codes and the transient fuel smell, and my experience with similar issues on another Toyota truck, I believe the VSV and vacuum lines were the problems. I think the original purge valve was functioning properly, but I now have a new one, so... Cool for me.So do you think change the vacuum lines is all that was needed?
Anyone ever just replace the valve on their charcoal canister. I just did that and it seems as though it has fixed the problem. I paid $60 dollars for the valve and so far the check engine light has stayed off? I was just wondering if anyone else has taken this route vs replacing the whole thing?
bluesquirrel: since I'm a 2004 guy w. interest in using under hood canister system, can you take a few shots of the engine bay. Want to see if I can accommodate that system.
That is interesting. By how much? Was this one full tank or more, and any change to driving habit?Update.
After replacement of listed parts: vsv, vacuum purge valve, and all vacuum lines in the evap system.
I have noted an increase in fuel mileage. I've yet to calculate, but my driving range has increased per mile, a noticeable amount. No driving behavior changes
I've noticed the change over the last 1000 miles, about 70/30 split driving city/highway. I have not changed my driving habbits. I'm going to calculate on my next fill up. I was at 14-14.5 MPG.That is interesting. By how much? Was this one full tank or more, and any change to driving habit?
I purchased an assortment kit. Unable to linkyes i was wondering 5 or 6mm
Cutting the canister open, replacing the charcoal, and resealing it was a single afternoon job.@bluesquirrel I will follow your lead. I need to do this ASAP as its hot and if I drive for more that 30 minutes the pressure in my fuel tank and the smell is crazy. I will order and replace vsv, vacuum purge valve, and all vacuum lines in the evap system and see if that fixes the problem. Maybe a new fuel cap as well. Trying to avoid buying a new canister if possible. FYI - I've han no engine light issues.
