Deleted 2X post
No way to tell, but that's as likely as not.After doing some reading, I'm wondering whether my knuckle studs all sheared or maybe the first three just backed out and the last one sheared?
The torque value is typically calculated based on the thread diameter, and if it's a known failure point, the tensile force it usually sees, or is expected to see. So there is not any reason I can think of to reduce the installation torque. You're correct that grabbing this shoulder is a problem, but there's a snubber made for this, even though I've never seen anyone use one. This is why most manufacturers don't use them, unless they can install them on the assembly line. The process is typically to use two nuts, jammed together, and then stake the stud. This reduces the deformation resulting from using two nuts to drive the stud, and prevents (hopefully) the stud from backing out.This is where we get into a grey area that Toyota does not clearly define.
There is a published torque value of 71 lb-ft for the steering arm-to-knuckle side nut but no mention of stud-to-knuckle torque or the use of a locking compound.
Typically Toyota will pre-coat specific fasteners if they have determined a locking compound is necessary. Driveshaft bolts and nuts are one example that comes to mind. Knuckle studs are not pre-coated.
The "standard bolt torque specifications" chart describes stud bolts in a hardness of 4T and 6T however torque values listed refer only to "hexagon head bolts and "hexagon flange bolts". Stud bolts are not called out.
The standard torque value for a 4T 12mm hex head bolt is 35 lb-ft and a 6T 12mm hex bolt is 53 lb-ft. The shoulder of a stud bolt is obviously significantly smaller than a bolt head and logic would suggest the value should be reduced but I have no idea by how much.
In view of he job the stud does I imagine it is a 6T. I have always tried to get them somewhere around 45 lb-ft and I have not used a locking compound. I have not had studs loosen on me using this procedure but, as always, YMMV.
Common in cases where the steering arm has been removed at some point prior and not properly reattached.
Hence the phrase:In my case.it was not a.stud torque.issue. I did not remove studs when rebuilding axle 2 years ago.
It.was a sheared stud. Didn't check studs when leaving trail and 130 miles.later all hell broke.loose.
Leson learned.
Never leave trail without checking those studs. In fact everyone should do a quick visual inspection or you may end up like me.
Thank God this happened in front of my house. Hard left U-turn into my driveway and heard/felt clunk and steering loose. Pictured is what I've got. It looks to me like I've lost my four bolts that attach the knuckle arms to my passenger side steering knuckle. In next post I've pictured what I found in the street which I think may be last bolt which sheared off...?
Cleaned off sheared stud end from post #7. I guess this thing is a hero because it was keeping my steering together by itself until it failed. I have the cone washer, flat washer, and nut back on.
I'm told there is supposed to be a fitting on the end of this stud so it can be torqued into the knuckle. I don't see any fitting you can put a wrench on, on the end of this. Does anyone think this is was a hand-tightened hardware store part from PO or am I missing something? Would a mechanic have ground it off?
That looks to be a correct, original stud that was sheared off. Each stud has a stud, cone washer, flat washer, nut. Do NOT lubricate them when you assemble. They should be CLEAN AND DRY. (unless you decide to use Loctite....)
You had essentially the same issue as mine. I forgot to mention that on mine, one was sheared off, two unscrewed and fell out, and one was hanging on by one or two threads. You last one sheared off as you pulled into your drive.
The NEW factory studs will have a make Torx head to them in order to accept a socket. That tip shears off pretty low in the toque range. I used the double-nut method to torque mine into the holes (as everyone states NOT to do) and I also used the Red Loctite.
You can buy all (4) cones, washers, nuts, and studs for about $12 per stud assembly, so $50 per side of the truck.
Many folks that wheel a lot check their nuts both before and after they are on the trail. Then they just play with them while they're out.
The key is making sure everything is CLEAN AND DRY when reassembling.OK thanks. I bought a replacement hardware kit from NLXTACY; it has torx heads and comes with a matching socket--nice. Will attempt to remove the sheared stud end with an ez-out. Thank you for the install tips. If steering remains gimpy after I replace the studs, I'll replace the knuckle. Looking at a knuckle/birf resto soon anyway....
Checking mine as we speak!Many folks that wheel a lot check their nuts both before and after they are on the trail. Then they just play with them while they're out.
Mine were just a bit loose from spec.Checking mine as we speak!
OP: I'm glad you are safe, and thanks for the reminder for us all.
n
Sorry, I still am unclear...are the studs not being properly torqued into the knuckle, or the nuts not properly torqued on the studs?
