Knew what this was going to be before I opened the page...
Seems to be all too common lately.
The knuckle and trunion bearings are likely damaged. If you can extract the broken studs,fit 4 new studs and get everything lined back up you might be able to drive it a short distance at low speeds (in an emergency).
You are better off just towing it, and as said by others check your nuts, I don't understand how you never noticed it was loose. Ok you probably trashed the knuckle, and for sure the trunion bearings, I am glad you had this happen at a slow speed in front of your house and not at high speed
