Castrol VMX-M appears discontinued .... Suggestions on gear oil for manual boxes and transfer cases?
Toronto, NSW, Australia
I'm using VMX-M but it looks like it's no longer made as it's NLA from most auto parts stores here now. I last bought some a year ago for a gearbox and transfer case oil change.
Seems VMX-80W is the replacement product?
I know it's not the only suitable gear oil out there so what other suggestions are there?
No is not. It's a separate product, and not an equivalent.
Very similar specification, and a lot use it without issue in boxes with no synchro issues
If your having notchy or stubborn gear shifts, search for Redline MT-90
Ta I know of MT-90 - is it available in Australia or does it need to be imported from a US seller?
I believe the gear oil for any sort of older landcruiser needs to be the GL-4 type not GL-5?
Is MT-90 good for the transfer case as well?
Ive been using the Penrite one on the right for as long as I can remember in my Xfer case with no probs
Trying to get some leftover stock of VMX-M so I can at least do one more oil change with that, but failing that I'm curious about Redline MT-90 as I've not seen in recommended for 4wd's but have seen it recommended for cars with manual boxes.
What's the real-world view of GL-4 alternatives in H150F and H151F boxes and in the mating transfer cases for 80's?
Tried the Nulon Slick shift additive? My Corolla has a dodgy 2-3 syncro and it really helps it.
(i know the VMX-M is the prefered option but this could help)
Nearly every mechanic I've dealt with in relation to the 80 in my time owning it has recommended that gear oil, but I know there are loads of GL-4 spec oil products.
Redline Synthetic MT-90 has worked well in all of my Toyota manual transmissions. I typically use their 75W90 in the transfer cases but I understand that MT-90 is fine for that application. Not sure how easy it is to get Redline Synthetic Downunder.
There's a place on Ebay here that sells MT-90 for A$131 per gallon (3.8 litres) but some places on Ebay are selling it up for around (and over) A$200 a gallon! Is it really worth that sort of price? I haven't come across an actual auto parts place that stocks it in a retail store.
Seems to be about the going price across several online sources on Australia.
Ebay still has Castrol vmx-m available at half the price
Ok so been a while but confirmed the 'replacement' product for Castrol VMX-M is Castrol Transmax Manual 80W (p/n 3429680 in 4L bottles). If you want bigger quantities, it can be found in 20 L (plastic) drums, and probably much bigger drums if you're a shop or just want to keep a large quantity around.
I am right now using up the last 20 L drum of VMX-M I could find for my 80 series gearbox and transfer oil changes. I do not know what the exact chemical spec differences are between the VMX-M and the newer product.
