Ideal the same as the front tcase flange
▲True▲ only without a DC shaft. You want your pinion to point directly to the t-case with a DC.
Goi g part time to cpmbat drive line vibrations below 5" of list is stupid. There are solutions out there.
Ideally the same as the front t-case flange
IdeallyProbably not gonna happen.
I think @baldilocks pointed out in another thread, the front diff pinion points upward in standard trim and with caster correction in place. Without caster correction, the pinion angle increases, but the drive shaft angle flattens out.
The front pinion and t case flanges will always be out of parallel without modifying the diff housing.
nice rebuttals, care to expand on it ?
I noticed that while I was in there last night. Strange. I'm doing a DC shaft from Tom woods, it's at my house tomorrow. Stoked.Btw, Toyota went with a "broken back" style front driveline meaning that rather than going for parallel flange angles they are equal but opposite in relation to the driveshaft. Cadillac did something similar in the 60's to minimize the driveshaft hump.
According to your measurements you have a 3 degree working angle on the front u-joint and 12 degree on the rear, a recipe for vibes. Unfortunately, and I'm sure others will disagree, I believe the caster adjustment is the root of the problem. Toyota did a pretty good job of controlling the pinion angle through suspension travel in regards to drive line working angles but they did it at the expense of poor control of caster change through suspension travel. Its a catch 22, The more you change pinion angle to correct caster angle the more you increase the potential for drive line vibration.
The way I see it, you have 4 choices, 1. Reinstall the factory bushings at the expense of stability at speed(thats the route I chose), 2. Install a DC driveshaft(you're within the ideal pinion angle to make it work but 2 more degrees of positive caster would put you spot on). 3. reinstall the factory bushings and do a cut and turn(could get very expensive as you may need to covert to front steer). 4. Do a part time conversion and not worry about the angles as the driveshaft never spins fast enough for any of it to matter.
Cut and turn has it's own set of problems.
I did a cut and turn on my hdj81 with a 4" lift and factory bushes, I would not be in a rush to repeat it.
It increases pinion angle, and highly likely causes tie rod interference on radius arms.
I had 4° caster. Handling was exceptional.
Tie rod interference means a high steer conversion, or a modified tie rod set up.
I had a heavy duty tie rod made, using heim joints and drilled out the taper in the steering arms for bolts and spacers to bolt through the heim joints to lift the tire rid and get clearance from the radius arms.
I ran full time 4wd, and the standard shaft. With new uni joints, I had a slight grrr, but it was tolerable.
For a daily driver, I would be maintaining positive caster and predictable handling.
I have heard that before but OBDII does not lie. Just returned from another 1500 miles trip and never saw 200°.
So you confirmed with obd2 reader and it's actually running that cool?
I just went thru this with mine. Gauge sender was going bad but it would drop to 1/4 then jump back to 1/2. Replaced gauge sender (and ecu sender while I was in there) and it read about 20* too high, swapped to a different brand and it reads a little low but I'm tired of messing with it, at least it's consistent. (And this is the part to advocate OEM parts!)
Also, do you mind posting a pic of your control arms? I'm also grinding mine for 4* caster clearance! I took enough off to drive the streets but I know it's rubbing even on bumpy turns, need to grind more before next off road trip.
I agree the OEM gauge is not a good judge of temp. My gauge has been modded to be more active reflecting small temp changes. The pic was taken raining at 7200' guessing I would estimate temp at 177° - 180° I have run both ScanGauge & Ultragauge and confirmed my 80 just runs cool, rarely seeing 200° anytime.
Picture not so great but I have a good 1/2" of clearance and you can see I still can make tie rod contact when flexed.
Makes me wonder if thats the bang I hear with the sway bar out wheeling hard. It only happens on the passenger side and only at full stroke. hmm.
My needs are definitely specialSome have special needs also one does not need PT to run solo on a front driveline but it will come in handy if you have front end issues.
I doubt you will hear a bang, the contact is not so abrupt. The contact is under flex and more sliding of the tie rod and arms. Who's plates are you running? Also you do not need to remove your sway bar I heard someone makes swaybar disconnects to get you home safely.
Plates? Also I know about your sway bar kit cause I'm running it.
What are you using for caster correction?
Thanks for your product support.![]()
