- Thread starter
- #101
I wanted to play "flight of the bumble bee" for the fast forward section but I was too tired last night to download it and figure it out.
Realy nice work.
How are you going to finish those wheel arches?
Awesome
I love the fast forward
I challenge someone, on the next resto project, to video document the whole thing![]()
They will be welded to the side panels. More accurately they will be brazed to the side panels using the TIG torch and silicone bronze filler rod.
Uploading another vid now....![]()
Not sure if it is the same thing - I know I can get this Silicone Bronze TIG filler rod product as a roll of wire for my MIG also. The brand name I am using is Everdure (sp?)
No, just the Everdure product. But it doesn't actually melt the parent material when you use it so it is kinda like soldering. It's tricky to use because its a fine line between having a ball of molten filler and then it spreads way out with just a bit more heat. I tend to put too much on and then grind it off, which is Ok because I am using it for cosmetics rather than structure. Almost as a "metal bondo" or like lead filler bodywork in the old days. It is softer than the steel and grinds away easy.
Solid 1/16" and 3/32" diameter by 36" TIG filler rod. No flux core or anything like that, just the TIG gas, straight Argon in my case. I believe that was your question...
