- Joined
- Mar 8, 2013
- Threads
- 20
- Messages
- 222
Hey Mud guys, been on here for a coupe years and built a 60 that is still in progress as well as lurked and commented where I could, now I need some advice.
So I bought an lx450 for a family rig/daily driver/tow rig with a rod hanging out of it and bought a donor motor to build. I am a lead tech and have plenty of complete builds under my belt but there are some inherent questions I have about the 1fz.
Main bearing cap bolts and rod cap bolts both are a torque to yield (torque to spec then stretch 90 degrees) now all my experience with tty head bolts are replace them, or some manufactures have a 2nd and 3rd time torque to yield spec for already stretched. No info in Mithel or alldata has any specs nor do they say to replace the bolts. What is protocol for these bolts, Replace or just torque and call it good? If I reuse them, how many times can they be stretched?
Second question is about cometic head gaskets. I had the machine shop bore the block and machine the head but he was hesitant about decking the block because he could not find specs and didnt want a piston sticking out too far so he wouldnt touch it. My mistake was I installed the bottom end before inspecting the block surface and when I went to clean up I notice some pretty deep corrosion around water jacket behind 6 and in front of 1. Research said to take a flat block or something to keep the surface flat and lightly sand with emry cloth, I did a couple test runs with this trying to take off very little at a time and really watch what I am doing but it just doesnt feel right, plus all the contaminants are gonna end up in my brand new bottom end. Hence the question in the first paragraph about the mains and rods being torque multiple times. I dont want to cheap out and want it done right. As I sand I keep taking a straight edge and checking down to .002 and so far its going very well it just doesnt feel right. Maybe someone has specs of how much can be taken off the block in case things go south I can give the machine shop a number to ease his mind.
Thoughts and suggestions? Any interest in seeing the build? I figure there are butt loads of 1fz builds on here so I wasnt too worried but I can throw some stuff up here if anybody wants.
