- Joined
- Sep 9, 2004
- Threads
- 199
- Messages
- 12,345
- Location
- Boise - Idaho
- Website
- www.snlandcruisers.com
- Thread starter
- #41
Whats the 5th gear change from Terrain Tamer a different ratio ?
Yes, that is correct and also a stronger 5th.
Cheers
I don't think there's ever been an issue with 5th gear strength in the H15# boxes. They are a heavy gear and integral to the main clusterYes, that is correct and also a stronger 5th.
Cheers
Not the dozens of reports I have read or watched on YouTube.
Obviously not as much of a problem as on the R151 but it is still an issue. 360Gearbox in Australia wouldn’t do an upgrade nor would Terrain Tamer if there was no issue.
Towing in 5th is a known issue in many manual trans, even the NV4500 which is more robust. The upgrades are dual purpose, better cruising speed in 5th and stronger 5th.
Cheers
So not saying you're wrong, but I'd be interested if you could show some comparison measurements of the standard 5th gear and the conversion 5th gear.
Is there a difference in the width of the gear?
Or a difference in other parts?
The trucks are looking really nice, i like your floor jack with the big wheels on it too.
The other HDJ81 I have been picking away at as time allows. It is an LSD rear 81.
Had the H151 in it rebuilt and fitted a Terrain Tamer performance clutch at the same time.
I just installed OME heavies all around, fitted @Delta VS radius arms and rear Panhard bracket, rebuilt the steering, rebuilt the knuckles and rebuilt the brakes all around fitting some reman Toyota calipers. Waiting on a few parts so I can put new bushes in all the rear control arms and rebuild the front and rear sway bars. I also just installed new windows runs and inner/outer window seals plus serviced the regulators. Power windows are working great now.
I just fitted some Trekboxx drawers in the back. Got a @Delta VS front bumper to fit to it and a Front Runner roof rack. Got a bunch of little things to do as well but the Cruiser is really starting to come around. Hood is getting painted black to deal with the clear coat rash. Most of the rest of the paint on the truck is good.
Cheers
Who did you have rebuild the tranny? I am trying to decide if I teardown my H151 or ship it off somewhere...
I’m struggling with the same stuck adhesive on my window frames from the visors
