this is look'n preeeeeettty sweet
Lookin good! Let's see some full side and rear shots...
Your departure angle is amazing... Are you gonna run a full rear bumper, or just between the frame rails? (don't know what your local laws are regarding bjmpers).
Thank you. It definitely gets "WTF?" looks driving down the road.
Doing some work today.
Filled the gap left from the roof cut with a piece of the old roof. I made a small lip that I plan on installing a led strip for a third brake light, or possibly a reverse light , if I end up ditching the factory lenses. Not sure ill do anything with it, but its there just in case.
I'm guessing it'll get cut off when you make the truck even shorter![]()
Maybe I missed it but what are you doing about the fuel filler, now you've cut the hatch off?
I'm lovin' this build.
Cheers
Sorry it took so long. Snapped a couple at work today. Crappy photos, but you get the idea. Still lots of metalwork to do to get everything solid and fairly decent looking.
I like the tail
Can you post a picture of the inside?
Ill get you one later today after work. It's completely gutted right now though. Once I get everything patched up I'm going bedline the majority of the interior.
Gutted is good, I just want to see how you brought it all together.
Little bit here, little bit there... Starting work on the tailgate. I have it pretty much all figured out how I'm going to put it together. Only thing I need to figure out is what latching system to replace the stock one with, and how to mount it so I can still remove the new acces panel I'm going to build.
And one just for kicks:
I see you got your sliders on. Have you had a chance to test them out yet?
