Hi All,
I just replaced my front brake pads 2 weeks ago and I have bled the system and the pedal feel is great.
Today on the way back home I heard a brake squeal/noise coming from the front right so I popped the tire out and everything seemed to be OK.... with the exception that squealers on the front pads were visible from the top of the caliper rather than the bottom...is this a problem....did I install them incorrectly??
Also I may need to use brake type grease on the sliding pins which I have not done so as of yet...any type that you would recommend and can I use it between shims as well?
Thanks
Al
Thanks
Al
