Bolt Pattern Question (7 Viewers)
Castle Rock, CO
Hi Everyone - I have a 2009 LC 200 and I am looking for a new set of rims to replace my stock. Reason being there are some stock TRD 4 runner rims available (with brand new tires on them) available for a great price. My question is the bolt pattern for my 200 is 140 and the bolt pattern for the TRD rims are 150. Everything else is a match. How much of a PITA is it for an offset if necessary or will they fit without? Thanks! - Joe
4Runner is 6 lug. LC is 5 lug. Won't fit.
You need 5x150.
4Runner wheels are not 5x150.
Not sure where you are getting the 140 number...?
2007-current Tundra wheels, Sequoia and 1998-present LC wheels will work for your 200. None of the 4Runner wheels fit your 09 LC.
Stock offset is +60mm.
Rock Warrior wheels (TRD Rock Warrior Edition Tundra wheels) are 50mm offset...so will add a bit of width to your stance. Depending on tire size, you can use down to about +20mm offset.
Here are the specs for the 4 runner TRD - I have confirmed it is a 5 lug wheel
ALUMINUM WHEEL; 18 x 8; 60MM OFFSET; 10 SPOKE; 5 STUD/LUG; 150MM BOLT PATTERN; MACHINED AND BLACK
That must be one oddball 4Runner...because 4Runners are 6 lug.
Post a link to the ad if you can.
Sorry, it’s not a 4runner it’s a Tundra...so the offset is still OK? Thanks again. This deal is cheaper than buying new tires :)
Thanks! I appreciate it.
